![]() Drives: 2SS 1LE Join Date: Aug 2019
CAN'T control LIGHTS due to canadian regulations.. can someone help ?
i don't know if this spec is new. i'm not in Canada but i purchased my car and shipped it all the way from there. I noticed a thing that American cars don't do.
which is when engine is on.. u can't control ur lights status as long as ur not in (PARK) gear. So when i'm running my car around sunset and the auto sensor indicates no sun. As u know the DRL will shut and the regular lights will turn on but i can't choose whether to just drive with full lights or not, and i can't even turn off the lights if i want to. - same happens at sunrise.. even when DRL is on i can't turn it off. i'd appreciate a help. I'm sure there is a solution for this which i don't know given that this spec is not equipped in our local cars here nor american ones. |
![]() ![]() Drives: 17' 1SS 1LE GBA-Black Join Date: Mar 2017
It is possible to turn off "Automatic Lighting Control", which I believe is your issue.
The way to turn it off, is to rotate the circular switch on the left side steering wheel lever clockwise. When you do it, you should see in the center of the instrument panel the message: "Automatic Lighting Off". If you would like to turn it on again, then simply rotate this same switch again and you will see the message: "Automatic Lighting On" I hope that this helps. I also suggest that you read through the user manual, in order to learn many other features. Good Luck |
Two Lane Blacktop
Drives: '18 Camaro 2SS Join Date: Jul 2019
My truck is from Quebec imported to NY, you can’t turn the DRL off in gear.
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2019 ZL-1 Join Date: Feb 2009
I believe on the Canadian vehicles you CANNOT disable DRL....
2012 Yukon XL Denali w/ 6.2 AWD |
Sleeping until Summer
Drives: '23 2SS 1LE, E500, Clarity, Miata Join Date: Jul 2021
I am in Canada, Daytime Running Lights (DRL's) are mandatory here, so you will always have some lights on. Sorry.
#6 | |
What u said does not apply on the CANADIAN cars and mostly the recent models. - Once engine is on and gear on drive.. u cant control the lights either scrolling or whatever There has to be a solution.
#7 |
Oshawa Launch Team (Ret)
Drives: 2022 Camaro (Order #: ZSRQPW) Join Date: Sep 2006
A number of years back, my father-in-law imported a US Cadillac into Canada. Before it could pass inspection, we had to get the Canadian GM dealer to install a device to enable the DRL. There must be a way to defeat it, just not sure. A dealer in your country may be able to help, or get some documentation showing how it's installed.
Dave
![]() 2022 Camaro 2SS 6M (Delivered Sept. 24, 2021) |
#8 |
![]() Drives: On Hiatus Join Date: Apr 2020
First question is why.
Second question is try the DRL fuse? |
#9 | |
