![]() Drives: 2017 Camaro Join Date: Jun 2011
Eibach Lowering Springs
Does anyone have pictures of their car with these springs? I have found some older threads but nothing that has pictures of these specific springs. If you are running them, any comments on the ride? I like the drop of the H&R springs, but the reviews say that they soften the ride.
Yes I know that changing the springs will cost time at the track, and that GM did a fantastic job with this suspension from the factory. Thanks for any help! |
Hard to want.
Drives: 2020 red hot 1SS 1LE Join Date: Aug 2017
I went with the H&R and love them. Dropped the car a little over an inch and it runs great on track. It did soften it a touch in touring mode on the street which I like. 99% of the time I’m not on the track. I’m never going to be a professional track rat but on the rolling hills of middle Tennessee the car still feels absolutely amazing.
Thanks for the feedback! Do you have any pictures of the drop? And any rubbing when you had the car on the track?
![]() Drives: no more camaro :( Join Date: Apr 2021
we have done a lot of research into springs. had eibach on my last 4 lowered cars and doing it again.
not sure if you notice or not but there's 2 different eibach springs for the camaro. one drops an inch and is 18-01-22 for the ss. the one you posted lists specifically for the 1LE cars and only drops .7- model 18-03-22. we are ordering the 18-01-22. I assume the difference has to do with the 1LE suspension being different than the ss? anyway H&R are great springs. had a set of those once but doing eibach again for this whip and the 01 version should yield the same drop as the H&R. |
![]() Drives: 2018 Camaro SS 1LE Join Date: Oct 2016
Eibach Springs on my SS 1LE. They ride amazing and have absolutely zero regrets. I had H&Rs on my A90 Supra and they made all kinds of noises and rode like shit. I'll never buy H&R Springs again for as long as I live.
Eibachs are all I'll ever run, unless it's a fixed, non-magnetic damper setup, in which case I'll run KW V3 coilovers.
2018 Chevrolet Camaro SS 1LE - Hyper Blue Metallic
#6 | |
#7 | |
#8 |
Hard to want.
Zero rubbing on track.
#9 | |
we are going with the 1" ss drop since we don't have a 1LE car. |
#10 |
![]() ![]() ![]() Drives: 2017 Silverado/2017 ZL1 Join Date: Aug 2019
Look into BMR, I've had their stuff on other cars and they have lifetime warranty on sag. My eibach experience was terrible sagging .
https://www.bmrsuspension.com/?page=...616&superpro=0
#11 | |
![]() ![]() Drives: 2015 Camaro Z/28 Join Date: May 2009
2015 Camaro Z/28 - Red Hot
1978 Trans Am Y88 Special Edition 400/4 speed 2001 Mecham Trans Am #3 - 7.0L LS1 |
#12 |
They are the 1LE specific springs.
#13 |
@Blackmamba_1LE
Drives: 2017 1LE Join Date: Jun 2017
FYI to all... if you use SS springs on a 1LE the car barely drops is any at all.
Also 1LE's come about 1/2 inch lower than regular SS... makes sense why Eibach has .7 as the drop instead of 1inch like regular SS...
Florida High Performance: H/C Whipple LME 377 900WHP
#14 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2SS 1LE Join Date: Oct 2011
Cereal question, I can barely fit a high end low-profile jack in there as it is...can you still get a jack in when you lower it?
2018 2SS 1LE 2023 Colorado ZR2 2022 Stinger GT-line AWD |
