Too Many Great Choices
Drives: Grand Sport/Z07 Join Date: Jun 2009
Camaro 1LE Upgrade Possibilities?
I hear the Camaro 1LE can be ordered with the ZL1’s larger brake package. True? If so how much is it?
Are there any possibilities of the 1LE getting the DSSV suspension? Thanks
Hard to want.
Drives: 2020 red hot 1SS 1LE Join Date: Aug 2017
No and no. Not from the factory.
Thanks
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 1ss camaro Join Date: Feb 2016
ive seen people do both my buddy is currently selling his blue 1le with dssv
![]() ![]() ![]() Drives: 2023 Chevrolet Camaro 2SS 1LE Join Date: Jan 2020
There really aren’t any reasons why the SS 1le brakes would need to be larger. Unless you’re a pro driver I can’t see anyone getting any use out of the larger Zl1 brakes.
![]() Drives: 2021 1SS 1LE Join Date: Nov 2020
I have purchased a used set of ZLE brakes and also the DSSV to install with my build. (I'm doing things in deliberate process to see what actually helps and what doesn't)
https://www.camaro6.com/forums/showthread.php?t=594295 I bought these before I had a chance to haul ass in the car and quite honestly, the stock stuff is more capable than I even thought. I will add the brakes and DSSV at some point, but not before I add grip and different pads to try. Ken |
#7 |
oh shit nice that will be a good upgrade! i can get you in touch with my buddy in socal that did the dssv swap if you want?
#8 |
Thanks! Good information guys.
#9 |
#10 |
he has it for sale right now ! he got a e36 m3 racecar
#11 |
![]() Drives: 2019 Camaro SS Join Date: Nov 2020
I thought the SS 1LE already had the same brakes and magnetic ride tuning as the ZL1? What's the difference?
#12 |
zl1 has magride zl1 1le has bigger brakes and dssv
#13 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2SS 1LE Join Date: Oct 2011
Same 6 piston front calipers, but the rotors are smaller F and R, because the car weighs less. I’m not sure if the difference is in the caliper or mount, but all the other aspects like piston size are the same.
2018 2SS 1LE 2023 Colorado ZR2 2022 Stinger GT-line AWD |
#14 |
Good stuff, thanks.
