Old 07-18-2021, 04:44 AM   #1
warren3537
warren3537's Avatar
Drives: 2019 Red Hot ZL1 1LE: 2012 RAM 2500
Ethanol free 93
Has anyone tried it? and if you have how did your ZLE perform? I have access to it in my neck of the woods.
warren3537 is offline   Reply With Quote
Old 07-18-2021, 05:54 AM   #2
Flowtie1
Drives: 2017 ZL1
IMO no advantage over 10%ethanol
2017 ZL1 M6 Silver Ice Metallic
Flowtie1 is offline   Reply With Quote
Old 07-18-2021, 06:22 AM   #3
Z OH 6
Drives: 2024 CT5-V Blackwing
I would rather have 10% ethanol 93 for the added cooling effect.
Old 07-18-2021, 07:11 AM   #4
avalonandl
avalonandl's Avatar
Drives: 2019 ZL-1
I doubt any change. I tried it on my 2017 SS and zero difference. Hell I put 87 octane in on a road trip and my mpg was no different.
Old 07-18-2021, 02:51 PM   #5
Heartbreaker
Heartbreaker's Avatar
Drives: 2020 Camaro ZL-1 1LE
The ZL-1 loves Octane. 25 hp going from 93 to 100. Don’t worry about ethanol. Increase octane for HP.
Home Track: NCM Motorsports Park
Heartbreaker is offline   Reply With Quote
Old 07-18-2021, 05:39 PM   #6
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
I wouldn't spend more for 93 with 0% ethanol. Top Tier 10% works just fine.
Old 07-18-2021, 07:19 PM   #7
Camaro1973
Camaro1973's Avatar
Drives: 2019 ZL1
There’s 0 gains going from 93 to 100 unless your timing was increased. Octane alone doesn’t create more power , octane +timing does because it’s more resistant to knock.
If your max Timing is 20 degrees it doesn’t magically increase itself for 100 octane.
ECT,IAT,MAT = yes
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90
Old 07-18-2021, 07:27 PM   #8
cgdelena
cgdelena's Avatar
Drives: 2019 2SS
'Ethanol contains less energy per gallon than gasoline, to varying degrees, depending on the volume percentage of ethanol in the blend. Denatured ethanol (98% ethanol) contains about 30% less energy than gasoline per gallon.'
cgdelena is online now   Reply With Quote
Old 07-18-2021, 09:27 PM   #9
Revalot
Drives: ZL1/1LE parts added
Location: Somewhere around Texas pines tress and smooth asphalt
I believe that one tank of ethanol free gas will not make a difference in performance or gas mileage, but I also believe that if a person ran ethanol free tank after tank on premium gas, the ECM would notice the difference over time and mileage would increase 4-5 miles per gallon, and we know what ethanol does to a fuel system if a automobile sits up for weeks and months, it will cause a severe build up.(Another example)For instance when I 1st purchased my 5.7 tundra I was getting 21 mpg on the highway and 16 mpg city, then in 2009 ethanol came in, there was a recall on gas pedals, ethier ethanol or the gas pedal made my mpg go down to 16 mpg for hwy and city, I'm betting ethanol, my wife's 2012 5.7 toyota sequoia gets 16mpg also no matter what. Ethanol is not worth the trade off.
Revalot is offline   Reply With Quote
Old 07-18-2021, 09:42 PM   #10
CW3SF
CW3SF's Avatar
Drives: 2019 Chevy Camaro ZL1 M6
Originally Posted by Revalot View Post
I believe that one tank of ethanol free gas will not make a difference in performance or gas mileage, but I also believe that if a person ran ethanol free tank after tank on premium gas, the ECM would notice the difference over time and mileage would increase 4-5 miles per gallon, and we know what ethanol does to a fuel system if a automobile sits up for weeks and months, it will cause a severe build up. For instance when I 1st purchased my 5.7 tundra I was getting 21 mpg on the highway and 16 mpg city, then in 2009 ethanol came in, there was a recall on gas pedals, ethier ethanol or the gas pedal made my mpg go down to 16 mpg for hwy and city, I'm betting ethanol, my wife's 2012 5.7 toyota sequoia gets 16mpg also no matter what. Ethanol is not worth the trade off.
Interesting. I had ethanol in my tank all winter and constantly since I installed flex fuel kit and I haven’t noticed any negative effects whatsoever. I do plan to run some 10% 93 and a bottle of injector cleaner thru it in the near future but strictly from a preventative stand point not due to any issues. I make a lot more power on the ethanol blend than I do on 93.
CW3SF is offline   Reply With Quote
Old 07-18-2021, 11:12 PM   #11
JonDaddy82
JonDaddy82's Avatar
Drives: 2018 ZL1 Coupe NFG M6
Funny, I’ve tried the 100 octane at NCM and ran the exact same trap speed at Beech Bend vs standard 93.
1989 Forumla 350 WS6 <- High School
2000 Trans Am Firehawk <- After High School
2017 Colorado Z71 <- Daily
2018 ZL1 M6 <- Not Daily
JonDaddy82 is offline   Reply With Quote
Old 07-19-2021, 12:37 AM   #12
gtfoxy
Drives: '21 Wild Cherry ZL1
Has anyone done a STFT/LTFT comparison between non-ethanol vs 10% E content in comparable octanes?
Old 07-19-2021, 05:40 AM   #13
FoundNemo
Drives: 2019 ZL1
ECT,IAT,MAT = yes
Wrong. Ted Jannetty has dynos showing gains of 20-30rwhp on a bone stock car going from 93 to 100 octane.
FoundNemo is offline   Reply With Quote
Old 07-19-2021, 06:12 AM   #14
L78toLT1
L78toLT1's Avatar
No way 10% e is costing you 4 - 5 mpg vs non-e 93. E60 only costs me 2mpg compared to 10% e 93
Baby Blue
