![]() ![]() Drives: 2017 Camaro SS 50th Anniversary Join Date: Apr 2021
Misfire with Procharger Recommended Plugs
Had my procharger p1x working fine for a couple of months here with stock plugs. Finally got around to replacing the stock plugs with the recommended NGK 6510 with .035" gap hoping for even better results.
Getting bad misfire under WOT, but running perfectly fine at less than maybe 75% throttle. 0x7E8: P0300 - Random Misfire Detected (Pending) 0x7E8: P0303 - Cylinder 3 Misfire Detected (Pending) Obviously I'll check cyl 3 first. I reseated the plug wire on that cyl. But the random misfire kinda makes me think the overall config is just wrong. Since it runs find at less than WOT, makes me think it's not a completely bad wire or plug. Its still firing, just not under full load. Changing those plugs is a pain, so thought I'd get some input here on what I might try next. Was going to open up the NGK plugs to .040" first, if that doesn't work, I'll put the original plugs back in. Wondering if anyone else has experienced anything similar. UPDATE/EDIT: The TLDR... the recommended plugs and gap work MUCH better than the OEM plugs. It was a damaged plug wire or two that was the issue. Last edited by cjperformance; 07-22-2021 at 11:46 AM. Reason: Update on Solution |
Moderator
Are you running headers? The stock plug wires, in my case, got brittle very quickly and weren’t happy coming off...easy to develop a crack IMO. I know some have had success, but not me. Lol
Plug could have gotten cracked during install. Did you buy a spare plug you can put in that cylinder?
#3 | |
![]() ![]() Drives: 2017 ZL1 Join Date: Jan 2017
I've had my fair share of misfires lately and I'd try the following:
Thanks for the input. Good points, all. I'll start with new plug wires. Sounds like the plug gap isn't likely to be the problem based on some of the above, and I could definitely see how the wires could be brittle and damaged.
![]() Drives: 2SS Join Date: Sep 2017
Gap the plugs to .042
Moderator
Too wide, in my humble opinion.
#7 |
![]() Drives: 2016 Camaro SS Join Date: Jul 2020
Was the car running fine when you swapped the plugs?
#8 |
Ordered some new Granatelli plug wires. Easiest thing to try first. Will update in a week or so once I install them.
#9 |
#10 |
If the car was running fine before you switched the plugs why would you change the wires? I would double check the plugs to make sure you gapped properly and no porcelain is cracked.
#11 | |
Moderator
I agree with your point about the plugs, definitely worth checking the gap and inspecting for cracks. Frankly, I always buy an extra plug or two every time I buy plugs. If you drop one or ding it during install you’re better off not using it IMO.
#12 | |
![]() Its entirely possible a plug or two was damaged, but I dont think so. Changing the plugs was very unfun... so since I want to upgrade the wires anyway, makes sense to try that first before I pull out the plugs again. However, if the wires dont fix it, then its almost guaranteed to be a bad plug or just bad config in general. Wire should arrive today sometime, but wont have a chance to install until the weekend. |
#13 | |
#14 |
![]() ![]() ![]() Drives: 2016 Camaro 2SS Join Date: Apr 2018
