![]() Drives: 2017 Hyper Blue 2SS Join Date: Mar 2017
Time to replace ?
What do you thin VW k? Looks like some cords are starting to show on the edge. Still a fair bit of tread left. These are SC3s.
Cords are showing. They are done
I have had tires like that flipped on the rim at the track just to finish the day but otherwise they are done. If you have a lot of tread left in other areas then you need to assess your alignment. What do you run and where was the cording (outside shoulder?) |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 2SS/RS Join Date: Dec 2009
Might be good enough to run the streets awhile.
Orange Krush II
#4 | |
![]() Drives: 2021 ZL1 1LE Join Date: Aug 2010
Time to replace. If you are tracking the car make sure you are swapping the fronts after each track day. The driver front takes the beating. The fronts will last longer if you do.
Yes def swap tires to make them last a little longer next time.
If you are wearing on the outside shoulder and tread is good on the inner shoulders then it’s time for some more negative camber. -2.2 to -2.6 (what you can get out of the stock assembly). Surprised you have that much outer shoulder wear on the track alignment. |
#7 |
![]() Drives: 2017 Chevy Camaro 1SS Join Date: Jun 2021
