![]() ![]() ![]() Drives: 2020 Zl1 A10 Riverside Blue Join Date: Mar 2020
Car oil and coolant temp high
So I was at NJMP on Wednesday and didn't go as expected. 1st session after about 15 minutes I got a pop-up on dash saying oil temp high. No CEL nothing just pitted in and let cool down. 2nd session 15 min in pop-up trans hot leave car at idle so pitted in.
Forgot to mention car has a JRE 125 package . Called my tuner and he said take it so they can check to see what's wrong but I'm about 2.5 hrs away. Anyone know what it could be? I'm thinking it's a bad thermostat. Car has a stant 15638 180⁰ thermostat. |
Thank you Al Oppenheiser!
125 package is 20% more power, so 20% more heat, but does nothing for the cooling system. Peak temp at NJMP was 90F this past Wednesday the 14th. A 180 thermostat opening earlier only buys you time, it doesn't add any more cooling. The cooling system can only reject so much heat, and it's likely maxed out around 95F stock on a track. So you were likely well past the car's capabilities.
But for the sake of our fellow internet mechanics, can you answer the following questions: What did your dash performance menu gauges say? Oil temp? Water temp? Oil Pressure? Trans temp? Did you put an OBD2 reader on it and get live telemetry from the ECU? What did it say? |
#3 | |
![]() ![]() ![]() ![]() ![]() Drives: 2019 ZL1 Join Date: Mar 2019
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90 |
![]() ![]() ![]() ![]() Drives: 2019 Chevy Camaro ZL1 M6 Join Date: Jul 2019
Are your headers ceramic coated or uncoated? Ceramic coating reduces heat tremendously.
#6 | |
I'll get info shortly I plugged in HPtuners fir the 2nd session. |
#7 |
![]() ![]() Drives: 2017 ZL1 Join Date: Jan 2017
I recommend the 174° Katech T-stat over anything based on having a failure of a JET 180°. I also updated desired ECT, mech thermostat, and desired % control in HP tuners to match the tstat. I'm at 91% fan by 208°F (100% beyond that) as where stock hits 92% desired fan at 237°F.
Did you remove the water separator in the cowl? I've converted my IC loop over to distilled water w/water wetter and that has helped about 10°+ on MAT.
#8 | |
#9 | |
#10 |
![]() Drives: 2021 Chevrolet Camaro ZL1 Join Date: Apr 2021
I believe he is referring to the plastic piece bolted under the hood that protects the ZL1 engine from rain. At the track you should remove it for better air flow
2021 Camaro ZL1
ADM S/C Expansion Tank Dual Aeroforce gauges Eibach Pro Lowering Kit Oracle Side markers (Paint matched) Rear window "wind screen" Xpel Paint Protection Ceramic Pro Coating |
#11 | |
Manual says to remove this when you are racing!
#12 |
Yes I removed that the minute of bought the car. I also have the 1LE vent kit for the power steering.
#13 | |
Hp tuners highest temps ECT - 253⁰ EOT - 302⁰ |
#14 |
Can you share the log ?
