![]() Drives: 2019 ZL1 Join Date: Oct 2019
CSP Racing 2" Longtubes w/Jet Hot Coating - pics inside
Buddy's parts just showed up from CSP Racing after a trip to Jet Hot. Fabulous quality for the headers. G-Sport GESI Gen 2 850hp per bank cats, 304 stainless, full mandrel primaries, merge collector spike for scavenging, heavy duty stainless hardware for header bolts and collector nuts/bolts, o2 sensor goop, o2 extensions, etc.
Reports coming back soon on fitment. |
![]() ![]() Drives: 2017 Camaro SS, 2011 Corvette GS Join Date: Feb 2019
Look nice but if/how well they fit is most important.
![]() ![]() ![]() ![]() ![]() Drives: 2019 ZL1 Join Date: Mar 2019
They fit fine. I’ve already posted several screenshots.
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90 |
Master baiter
Drives: 17 NGM ZL1 Join Date: Aug 2009
Too bad they get mostly hidden.
Heard nothing but good things about these. |
They will be welding up a Ballenger Wideband on the drivers side ahead of the cat and after the ball joint, using a NTK lab grade sensor for his car. I think he picked up ARP stainless bolts/nuts as well for the collectors. Will post it up once done.
Is there any reason to go with the CSP headers over the Kooks? It looks like it would be about $200 cheaper for nearly the same thing with the Kooks.
#7 | |||
CSP's headers are designed to have the most clearance possible for all available headers to eliminate false knock concerns and to ease the installation as well. They are custom made by Stainless Works to CSP's specs. CSP actually sent the requested changes to Kooks (Andrew did) due to the false knock/vibrations/contact at times and they blew him off, so he made his own. These headers should be able to use the stock knock profile vs having to customize it as much as with other aftermarket header designs. In addition, CSP is the only one with the G-Sport GESI Gen 2 EPA Compliant cat option which are rated to 850hp per bank, vs the standard 350-500hp per bank like Kooks green cats. They are larger diameter and spiral wound internally like HJS cats to help avoid blow out of the internals at high power ranges. Video about the headers from CSP: External review and description of the headers: Link to the cats' manufacturer: https://gsportbygesi.com/high-perfor...tems-products/ |
#8 |
Red Bull
Drives: 2017 Chevy ZL1 Join Date: Dec 2020
I have CSP headers and I wouldn’t buy any other brand!
#9 |
![]() Drives: '18 ZL1 1LE Join Date: May 2020
Same here!
2018 ZL1 1LE - Summit White, PDR, Rotofab CAI, 95mm TB, CSP 2" catless LT's, JMS Voltage Booster, AEM X-series WB, DSX flex fuel sensor, Banks Data Monster, Tuned by Ted Jannetty, 5% Tint, Blackvue DR900S-2CH, Diode Dynamics lighting, IGL Kenzo ceramic coating
#10 |
![]() Drives: 18 ZL1 1LE Join Date: Apr 2013
I’m about to order the same setup. When you choose the catted option, do they also give you the non catted pipes too if you ever decide to go catless?
#11 |
No they do not. Stainless Works wont ship catless pipes with component cats in the box or cats added to them. As such, when you get the GESI Gen 2 cats already welded, that is all that comes. Check stock fyi, G-Sport is re-branding their cats and there is a shortage (as with everything these days).
#12 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2024 CT5-V Blackwing Join Date: Sep 2020
Nothing wrong with the Kooks headers, top shops like Vengeance Racing uses them. Seems like the biggest decision maker is cost. CSP is cheaper and uses ball flanges which some prefer. Both headers are fine, as well as ARH.
#13 | |
![]() Drives: 2019 Camaro 2SS Join Date: Aug 2020
Think there’s any concerns about having the wideband after the ball joint or should be good to go?
2019 Shock 2SS A10. 2650@10psi/LPE HPFP/XDI+30/LT4 LPFP+JMS/Soler 95mm/Rotofab, E65, CSP 2” Headers/GESI GenII Cats. MM Wild/GM SG3 suspension/1LE Brakes, Velgen VF5 Wheels/GY SC3. JRE Tuned.
#14 | |
