Old 07-12-2021, 06:00 PM   #1
Davescamaro
Drives: Chevy camaro
Borla mid pipe?
Is it worth it? The oem one is about the same diameter and was curious if this actually does anything including sound difference.
2019 Camaro 1 LT 2.0 Riverside Blue Metallic, ZZP strut bar, K&N intake, ZZP catted DP, MRT axle back, Injen IC piping, Trifecta Elite tune, zzp heat shield, turbosmart diverter valve.
Knockoff zl1 sideskirts, gm front chin spoiler, 1le blade spoiler, diode sides, 20" staggered Asanti black labels, azenis 510 245/40/20 fronts, nitto 555 g2s 275/35/20 rears.
Davescamaro is offline   Reply With Quote
Old 07-12-2021, 09:49 PM   #2
whynotlikemike
Drives: 2018 Camaro
Without a cat delete, I would say it's useless.
whynotlikemike is offline   Reply With Quote
Old 07-14-2021, 08:18 PM   #3
Davescamaro
Mines hi flow catted to be emissions friendly. Running catless is no really gains unless you had a ridiculous turbo and ecm so tuned that you would rid of b1s2 codes and b1s1 air fuel codes.
Not saying its not wrong, but catless downpipes don't do a whole lot of power gains from catted when the fastest ltg is less than 600hp. At worst you losing 10whp and if thats the case, upgrade to an lt2 engine.
I was looking more at seeing regardless of cat, if the mid pipe upgrade would increase the engine noise. I ran catless DP before with muffler delete and it sounded like absolute terrible. I lost more power than stock.
Old 07-15-2021, 07:19 PM   #4
buckwam
Drives: 2021 camaro 1ls
I have a mishimoto cat back exhaust and I like the sound better than stock, specifically the turbo whistle. If you can find them on sale like I did, would be better than a mid pipe if you haven't already got an axle back kit. I can't say it gives more power but it is lighter than stock.
buckwam is offline   Reply With Quote
