![]() Drives: 2020 SHOCK SS 1LE Join Date: Sep 2016
Anyone have a 1SS 1LE with Interior spectrum lighting?
I have a 2020 1SS 1LE. My dealer installed the Structura Interior Spectrum lighting & footwell kit. GM Part#84043877.
The lighting changes with the drive modes. But I do not have the interior lighting menu to manually select the colors through the infotainment. The service writer is saying my radio is not compatible. I asked if the tech reprogrammed the BCM AND the HMI. Service writer said he would check with the tech and call me back. The kit came with an authorization code. I read the other threads where a member here had issues with his dealership to properly update his radio. I pm'ed him but haven't heard back. Anyone else run into this issue? Any help is greatly appreciated. |
![]() ![]() ![]() ![]() Drives: 2024 Riverside Blue 2SS 1LE Join Date: Mar 2016
From the post I have read over the years several people have tried installing the 2SS or 2LT info system and still have not had any luck integrating the aftermarket lighting systems. If I remember even an electrical engineer tried and had no luck getting it to work. Curious if anyone did get it to work. I would think someone would be selling a kit if they did.
![]() Drives: 2018 Chevrolet Camaro 2LT Join Date: Mar 2019
Sounds like the dealer just missed the programming step. Althought it is possible that since they discontinued the kit in 2021(?) that it might not be possible on a 2021. Even the IOB radio can use the kit but in that case there is a switch panel to control the lighting which I beleive goes where the hud control goes in the higher end cars.
#4 | |
![]() ![]() ![]() Drives: 2017 Silverado/2017 ZL1 Join Date: Aug 2019
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 1ss camaro Join Date: Feb 2016
unless your trying to allure jailbait i dont get why anybody would care about adding this lol
