Old 07-10-2021, 02:14 PM   #1
74z/28
Drives: Looking
Help, she wont start!
Anyone have an idea on what to do? I have a 2018 ZL1 A10 with 58xx miles. The only engine mods are: Soler TB, Soler throttle controller, WeaponX blower lid and Granatelli 0 Ohm plug wires. I had it out this morning and it ran fine. Went to start it up early this afternoon and it wouldn't start. It cranked and sputtered. I got the "reduced power" message. I finally for it to start but it would only idle. It would shift into gear but the pedal didn't rev the engine at all. I disconnected the battery for an hour and tried again with the same results. I disconnected the battery again and checked the connections of the TB and intake sensor.
I cant drive it to the dealer like it is now. Anyone have an idea on what to do?
74z/28 is offline   Reply With Quote
Old 07-10-2021, 02:17 PM   #2
2SS Capt
2020 Shadow Gray 2SS
2SS Capt's Avatar
Get an OBD-II reader and pull the codes, your CEL is on so there are codes present.
Old 07-10-2021, 02:28 PM   #3
avalonandl
avalonandl's Avatar
Drives: 2019 ZL-1
TB connection?
Old 07-10-2021, 02:41 PM   #4
Chef-j
Drives: 2018 Camaro 1SS
Put stock back on and see.
2018 1SS 6MT: SOLD
Chef-j is offline   Reply With Quote
Old 07-10-2021, 02:46 PM   #5
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
1. pull codes.
2. remove the throttle controller at least.
3. if #2 doesn't work, put the whole car back to stock.
Old 07-10-2021, 04:44 PM   #6
74z/28
Drives: Looking
Update: I charged the battery as it was low for some reason. After re-seating the TB connection and connecting the battery cable the car started right up. It seemed to run and drive normal, but I was only able to take it for a short drive as it started to rain. The check engine light was still on and it gave the "service rear axle" message once. I read the codes and had these 2: P0697 (sensor reference voltage “c” circuit open) and a P2122 (throttle/pedal position sensor/switch “0” circuit low input). I wrote an email to Mike at Soler asking his opinion. I might be putting the factory TB back on to see if that fixes the problem.
Old 07-10-2021, 05:32 PM   #7
hawk02
Coupe Newbie
hawk02's Avatar
I would suspect the throttle controller more than the throttle body. Remove it and see if the check engine light goes out.
Old 07-10-2021, 08:14 PM   #8
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
remove the throttle controller as stated above then clear codes. Recheck all spark plug wire connections as well.
Old 07-10-2021, 08:17 PM   #9
CW3SF
CW3SF's Avatar
Drives: 2019 Chevy Camaro ZL1 M6
This. I’d try this next.
CW3SF is offline   Reply With Quote
Old 07-11-2021, 03:01 PM   #10
semif18
Drives: 2018 ZL1 1LE White
Disconnect battery for 15 minutes.........that should fix it.........resets your Throttle Control Sensor......
semif18 is offline   Reply With Quote
