Old 07-08-2021, 06:27 AM   #1
TNfirstgen
Drives: 1969 Chevy Camaro 2021 Camaro LT1
Varying from stock diameter tires
I’m needing some advice concerning varying from stock sized tires. I have a 2021 LT1 with the stock 245/40R20 (27.7”) tires. I’m looking to switch to the MRR 1le replica wheels and run the factory 1le tire sizes, 285/30R20 (26.7”) and 305/30R20 (27.2”). Will this change in tire size cause any issue with the traction control or any other systems in the car? I’m worried the 1” overall drop in front tire size may make the unhappy, wether that be traction control or something else I’m maybe not thinking of. It seems the SS cars are fine doing this setup, but im concerned that LT1 may be different since it has 245/40s all around. Will this setup work fine without the car throwing any lights or warnings? What about the speedometer, will it be a great deal off?
TNfirstgen is offline   Reply With Quote
Old 07-08-2021, 06:38 AM   #2
WhiteMale
Drives: 23 ZL1 A10 Rapid Blue
One might assume they're OE sizes and would be OK but I'd be interested to hear other inputs as the basic advice is staying in a window from OE sizes that came on the car. I dont' remember if it's 1" up or down in diameter that can cause traction/stabilitrak issues.
Old 07-08-2021, 06:49 AM   #3
TNfirstgen
I’ll be very disappointed if going to a factory size of another car won’t work. I’ve seen several people do the change, but not got the clarification i need to go ahead and order everything. I considered going to a 275/35R20 front since it’s nearly the same size as what i have now, but then the front will be bigger than the rear and I’m sure that would not make the Stabilitrak happy.
Old 07-08-2021, 11:50 PM   #4
Scargoes
Scargoes's Avatar
Drives: '18 Hyper Blue 2SS1LE '20 Crush RSR
the overall OD of the replacement tires doesn't matter. The car won't be able to tell if you are running 25" tires or 27" tires. What matters is the size difference between the front and the rear. That ratio is what will set off a warning or cause undesired effects with stability control/traction control.
I'm not sure what tires you were thinking of running, but if they made a 295/30 that would bring the ratio down but still fit on the width rim without and serious stretching or pinching of the tire.
2018 Hyper Blue Metallic 2SS 1LE with Nav, PDR, and track alignment
1:28.95 Willow Springs Big Track
Scargoes is offline   Reply With Quote
Old 07-09-2021, 11:53 AM   #5
TNfirstgen
Thanks for that info. I’m leaning towards continental extreme contact sports. Not sure if they make a 295 with that AR, but I’ll certainly check. If that’s the case, and a 1le doesn’t have TC issues, I’d assume I’d be fine then, right? I would assume the 1le would have any special considerations, unless the tire size programming for the speedometer also would make TC not have issues.
Old 07-09-2021, 11:58 AM   #6
TNfirstgen
Another thing I have a question about is if i do decide to run a 275/35r20 front tire to help eliminate wheel gap, will that have ill effects if i run the 305 rear due to the smaller rear tire than front?
Old 07-09-2021, 01:34 PM   #7
You will have no problems, the difference is small enough and your new fronts will be a bit shorter than stock as well. I'd do 315/30/20 or even 325/30/20 in the rear, though.
Old 07-09-2021, 01:45 PM   #8
TNfirstgen
I may consider that in the future if i make more power, but i really don’t want to have to worry with the harness relocation and such just yet.
Old 07-09-2021, 08:13 PM   #9
Aaron07
Aaron07's Avatar
Drives: 2017 2SS F1FTY
It would seem that you would want to keep the OD as close to stock as possible for speedometer reasons, at least I am. I too have MRR 1LE wheels on the way with the Conti Extreme Contact Sport tires in 1LE sizes, 285/30 FR, 305/30 rear. (I am a regular SS) There are tire calculators online where you can compare your stock size to different sizes and see the mathematical differences. IMO keep close to your stock OD. EDIT: I am also lowered 1'' so I don't have the wheel gap concern that you do. If I was in your shoes that would also definitely be a concern of mine.
2017 2SS F1FTY/HUD/Mag Ride/NPP/Nav/M6/Mishimoto catch can/BTR stage 2 Cam kit/GPI ported LT2 IM and 95mm TB/Roto Fab CAI/Kooks Long Tubes ceramic coated/Borla S Type NPP catback/AFE lowering springs/1LE wheels/OEM smoked tail lights/Diode Dynamics side markers/Uniden R7/3D Maxpider floor mats/Adams graphene ceramic coat
Aaron07 is offline   Reply With Quote
Old 07-11-2021, 09:15 PM   #10
TNfirstgen
One thing that i found out is that SS and LT1s, although have different rear tire widths, have nearly the same OD (.1” shorter rears on SS). So with that fact, i believe it would be no different for me to run the 1le sizes. I will lower the car eventually, hopefully it doesn’t look too goofy for now if i go with the 285. Where did you order your wheels from? I’m going to use wheelfire i believe. Somehow they don't charge tax, so they are nearly $300 cheaper than everyone else.
Old 07-11-2021, 10:37 PM   #11
Baddawg53
Drives: 17 hyper blue 2SS M6
I switch my SS to 1le sizes and supercar 3's with no issues, then I put NT01's on and the car really doesn't like it. I have to run with all the nannies off with this setup. I'm assuming I'll have the same deal when I go 18 inch square setup.
Baddawg53 is offline   Reply With Quote
Old 07-11-2021, 10:39 PM   #12
TNfirstgen
Same size tires with the Nittos? I’ve heard tire sizes change from brand to brand, but if that’s the case the difference in front to back OD of the 1le sizes must be right on the limit.
Old 07-12-2021, 01:27 AM   #13
Aaron07
Aaron07's Avatar
I recommend AFE power lowering springs when you do lower.. I bought a complete wheel and tire package that includes the tires, wheels, lug nuts, new tpms, wheel weights, mounted and balanced from CarID.
