Old 07-07-2021, 06:26 AM   #1
FoundNemo
Drives: 2019 ZL1
Anyone know the stock ZL1 inlet pipe diameter at the throttle body in mm or inches?
Trying to figure out if a 95mm LT5 throttle body (with reducing adapter) will fit on the OEM intake pipe or not. I figured not but wanted to double check.
FoundNemo is offline   Reply With Quote
Old 07-07-2021, 07:53 AM   #2
JSH
JSH's Avatar
Drives: '20 ZLE
Stock is 87mm
2020 ZL1LE A10.
100 octane: 1045hp/1055tq.
Old 07-07-2021, 08:10 AM   #3
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Stock is 87mm and The reducing adapter for the 95mm defeats the purpose.
Old 07-07-2021, 09:35 AM   #4
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
Are you talking about the pipe from the airbox?
I know the adapter I've seen only re-clocks the 95 to fit onto a stock-type snout. This one doesn't reduce the size of the opening to 87 - it's the same as the 95. I'd make sure you get one that doesn't reduce, like King' said.
If you're talking about the elbow from the air cleaner, I'd say that it will probably fit. It might be tight, and you might have to try to do it after a drive, so the rubber is nice and malleable, but I think I've seen a stock elbow stretch over a 103. I do know that Magnuson makes a larger elbow for their CARB-kit. That could be an option if you need to do that.
'20 ZL1 Black "Fury"
Old 07-07-2021, 10:15 AM   #5
FoundNemo
Drives: 2019 ZL1
To clarify, i mean the black plastic intake pipe from the airbox to the TB, not the snout itself. The throttle body is 87mm, but curious the inside diameter of the black plastic pipe connecting to it.
Old 07-08-2021, 05:07 AM   #6
Zigg L1
Zigg L1's Avatar
Drives: 2018 ZL1 Garnet Red Tintcoat A10
The stock air box will not fit the lt5 95mm TB. If you are changing your TB why would you not change the airbox??
Zigg L1 is offline   Reply With Quote
Old 07-08-2021, 05:08 AM   #7
FoundNemo
Drives: 2019 ZL1
Not changing to the LT5 TB, just was checking the pipe diameter for another idea. All set tho thx
