Old 07-05-2021, 10:20 PM   #1
DylansZLE
DylansZLE's Avatar
Drives: 2022 Rapid Blue ZLE
Gen 2 PDR
Anyone have any insight as to whether the 2022 Camaros will be equipped with the gen 2 PDR from the 2022 Blackwings or whether we will be able to change/upgrade it in the camaro?
DylansZLE is offline   Reply With Quote
Old 12-21-2021, 10:47 PM   #2
mano_camaro
IYAOYAS
mano_camaro's Avatar
Drives: 22 1LE 2SS M6 Riverside Blue
I know my 2022 SS 1LE PDR is crap compared to my previous 2020 SS 1LE PDR.
I ordered a used PDR on ebay from a salvage ZL1, should be on the mailbox tomorrow.
Like many others i prefer to fix small issues myself and not deal with carelessness from the service dept.
2022 Riverside Blue Camaro 2SS 1LE/ PDR
2020 Red Hot Camaro 2SS 1LE/PDR /Sold
2018 black Camaro 2SS M6 Redline Edition/Traded
2016 summit white Camaro RS V6 M6/Traded
mano_camaro is offline   Reply With Quote
Old 12-22-2021, 12:37 AM   #3
Jofu
Drives: 2022 Wild Cherry ZL1 1LE
Could you expand on how the 2022 is worse than the 2020? I was not aware they were different.
Thanks!
Geoff
Jofu is offline   Reply With Quote
Old 01-20-2022, 09:40 PM   #4
tomster
RedLine
Drives: 2022 ZL1 1LE
Any updates on 2022 PDR?
tomster is offline   Reply With Quote
Old 01-21-2022, 02:09 AM   #5
MatthewAMEL
MatthewAMEL's Avatar
Only the Blackwing and C8 get the new PDR. It requires the new computing platform.
2017 HBM SS 1LE
Sold
2023 Wave Metallic
CT5-V Blackwing M6
2025 Hysteria Purple
C8 Z07
Old 01-21-2022, 02:11 AM   #6
Jofu
@mano_camaro, I'd still be interested to hear what the differences you saw between your 2020 and 2022 unit, and specifically what part got worse?
Thanks,
Geoff
Old 01-21-2022, 11:10 AM   #7
mano_camaro
IYAOYAS
Thanks,
Geoff
Greetings Geoff, the PDR is all the same still, but the one in my 22' 1LE had poor color issues with green and purple shadows all over, likely from a bad batch of PDR camera lens or something.
The 2020 1LE. PDR previously was very clear in comparison.
I installed the used PDR camera from ebay and is a little better so far.
Old 01-22-2022, 11:16 AM   #8
Odabo
Odabo's Avatar
Drives: 2023 2SS 1LE
I know adding the 2SS PDR deletes Forward Collision Alert. Does anyone understand why? I'm trying to decide whether or not to include it when I order.
Odabo is offline   Reply With Quote
Old 01-22-2022, 11:43 AM   #9
The cameras are probably different between the two options but compete for the same physical space and/or connectivity.
Old 01-22-2022, 06:02 PM   #10
Odabo
Odabo's Avatar
That makes sense. For me, the PDR is a nice to have because I'm a data junkie. Although I hope to track the car I'm not sure how necessary it is. So I'll probably not include it in my build.
Old 01-23-2022, 12:52 PM   #11
biker2k
biker2k's Avatar
Drives: 2018 2ss 1le
anyone know if you can upgrade a 2018 pdr to the newer 1080p versions
2018 2ss 1le roto fab dry, Stainless works 1 7/8 lt to 3'" x pipe with highflow cats to stock npp, soler 95mm t/b, edelbrock 2300, LT4 fueling , jms bap and dsx flex fuel, 618/620 on e45 rwhp
Jannetty Motorsports tuned
biker2k is offline   Reply With Quote
Old 01-23-2022, 01:43 PM   #12
MatthewAMEL
No you cannot. It's not just the camera that is changed out. It's also the computer on the backend.
2017 HBM SS 1LE
Sold
2023 Wave Metallic
CT5-V Blackwing M6
C8 Z07
Old 01-23-2022, 05:40 PM   #13
Nope, as stated above, there's a brick wall between 2016-2018 and 2019+ in the form of a new architecture that is not backward compatible. Nothing is impossible per se, but this would most likely turn into a very impractical rabbit hole.
Old 01-24-2022, 01:02 PM   #14
biker2k
biker2k's Avatar
ok ill just put that to rest then..
would be nice but not worth it.
