![]() Drives: 2017 Camaro ZL1 A10 Join Date: Jan 2017
Cam install opinion
My car is down due to an oil pump failure. I'm debating on if I should take the opportunity to do a cam swap while things are opened up.
I have a local quote for two options: Option 1: Oil pump repair only ($3,500)
Option 2: Cam and Oil pump ($6,500)
Other mods on the car already
Doing the cam seems pretty pricey. Might not be worth it too if I don't do headers and high flow cats so that's another 3K+ I'm sure. If I do go for the cam swap, any advice on the supporting mods (internals) to go with it while it's open? Decisions, decisions ...
2017 ZL1 Black, A10
Build: Magnuson 2650R, 103NW Throttle Body, Rotofab Big Gulp, Kooks 2" headers, Catless, AWE Touring exhaust, JRE Smooth Idle Cam, Katech Oil Pump, Elite Catch Can, JMS Fuel Booster |
![]() Drives: 2019 ZL1 Crush Join Date: Jan 2019
I would do a cam just to have more overhead on the fuel system for the 2650
2019 Crush A10
E-Force 2650 670WHP 615WTQ All besides the 2650 is bone stock down to the air filter. |
Drives: '21 Wild Cherry ZL1 Join Date: Aug 2018
If it were me & my car, I’d do it since it’s already apart.
#4 | |
![]() ![]() ![]() ![]() ![]() Drives: 2019 ZL1 Join Date: Mar 2019
If you have the money do it now. The engine is already going to be out and opened up. Install the cam, get the heads done (optional) and get headers on it and call it a day so you dont have to do it again and spend even more. Trust me, down the road you'll want to do it anyway ![]() I have a set of 2" kooks i currently have up for sale in the classifieds as well as offroad pipes and cats.
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90 |
![]() ![]() ![]() ![]() Drives: 2018 Hyper Blue ZL1 1LE Join Date: Dec 2018
If you already have the 2650 and need the pump repair, definitely do at least the cam. I would do heads too at this point. But seeing these prices makes me realize how much more it costs to mod this car vs others. $3500 to just repair this pump is painful, that would get you a new forged shortblock installed on a nice sport compact, seems like it's the engine R&R that kills us.
Former GM Technician
Drives: 2018 ZL1 A10, 06 Silverado Duramax Join Date: Sep 2009
If you can do the cam now!
If you don't, and get the itch for more later, you will only regret that you haven't done it now.
2018 Camaro ZL1 A10
Rotofab Big Gulp, Nick Williams 103, Magnuson 2650, 9.17" (14%) lower, 90mm upper, Vengeance Racing Heads (LME) Cam Package (Cammotion Stage 1), Johnson Lifters, DSX dual intank pump, Lingenfelter high flow check valve, Motion Raceworks Flex Fuel adapter, LPE Big Bore Hpfp, XDI 30% Injectors, BBK shorty headers, Custom 2.75" down pipes, Gesi Gen2 high flow cats, MM catch can. 2006 Silverado Duramax Diesel MPI Compound Turbo 40% over Injectors Efi Live DSP5 Tuning Follow me on Instagram: SwissZL1 |
#7 |
![]() ![]() ![]() ![]() ![]() Drives: 2017 Camaro 2SS A8 Join Date: May 2019
If you can swing it financially I too would have the cam installed now as well as the headers. I’d also consider a different lifter.
Did they/you spec the cam and is it above .600 and is this with the larger fuel lobe?
#8 |
![]() Drives: '17 ZL1 M6 Join Date: Apr 2021
Definitely do a cam since it will be apart..
What cam are you leaning towards?
'17 ZL1 M6
8xxwhp Magnuson 2650 |
#9 |
![]() Drives: 18 ZL1 Convertible Join Date: Jun 2019
Cam now for sure!!!
#10 |
Okay, overwhelming support for doing the cam
I hear you loud and clear. I wasn't sure once I saw the price tag for it. I don't think I can afford to do the headers at the same time.Up until my oil pump failed, I'd never really put any thought towards as cam swap, so I have zero knowledge on what I need to consider, what brand of parts to use with it. I have trust in my tuner. My only ask was to do a smooth idle, feel stock, except for the power so it's easier to sell down the line. Several of you advised doing the heads? I assume that's getting them ported? If so, where's a good place to get that done? Ballpark figure on it? What's the tradeoff between 32 vs. 38 degree lobe for fuel? 38 = more fuel, any downside? I see most are 32's.
2017 ZL1 Black, A10
#11 | |
You can go with a stage 1/2 cam that has a very slight lope with 32% fuel lobe and get the heads done at a reputable place. LME probably does the best head work. Texas speed is another one. Your tuner/shop can help you spec a cam for what you want. 32% lobes seem to be more common, i am not 100% sure why but its quite possible many just dont want to overwork the HPFP that much more then 32%. You'll be able to hit 800rwhp though on pump.
#12 | |
Katech has one specific for 2650 combinations, it is the K-Force 3 2650 Other smooth idle options are: Cam Motion positive dis. 220/236 -118 32% fuel lobe Jannetty smooth idle Lingenfelter GT35 Lingenfelter GT31 For heads porting, LME or Frankenstein
2018 Camaro ZL1 A10
#13 |
As an additional data point (yes, my car is an SS, but still), I have recently had JRE install their smooth idle cam (+32% fuel lobe) on my car, and it's close to stock but definitely has a slight lope and "tremble", it will not be mistaken for a stock cam.
I for one love it and the changes are mild, but they're definitely tangible (just in case you think it would feel 100% stock).
#14 |
I say upgrade your cam/valve train as early as possible when you start down the "Mod Road."
2020 ZL1LE A10.
LME LT4 390 short block, LME CID Heads, Kong E2650, FBO. 15" conversion, MT ET Street R 325/15. 100 octane: 1045hp/1055tq. 100 octane + Meth (1x10+): 1117 hp/1067 tq |
