Old 06-23-2021, 04:56 PM   #1
GermanMuscle
Drives: 2019 Camaro 1SS 1LE
SS 1LE - Remove Rotor Bolts
How have others removed the front rotor bolts that hold the calipers in place on an SS 1LE?
I have tried the following:
1. Hand Wrench (hahaha)
2. Bought an Impact Wrench that claims 250 ft lbs breakaway torque
3. Heat Gun and Impact Wrench
Bolt hasn‘t even moved. Any tips?
GermanMuscle is offline   Reply With Quote
Old 06-23-2021, 04:57 PM   #2
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
breaker bar and some force worked for me...
Old 06-23-2021, 06:34 PM   #3
GermanMuscle
That worked! Thanks
Old 06-24-2021, 04:37 PM   #4
Cool SS
Drives: Black 2017 Camaro 2SS
250ft lbs ain't enough. Return that impact driver and get the Dewalt 20V Max XR Impact Driver with 700 ft lbs torque & 1200ft of break away force. You'll thank me later. Strong enough for everything!
Cool SS is offline   Reply With Quote
Old 06-25-2021, 10:25 AM   #5
Mountain
Mountain's Avatar
So, it's not uncommon for people to have a hard time removing the front caliper bolts. There is a good amount of torque there, and the access to get to the bolts is slightly awkward.
I've just used a good (stiff, robust design and of decent length) breaker-bar. I forget if I slid-on a portion of a jack handle to initially break the bolts loose.
Slow, steady movement is better than fast, instantaneous movement on those bolts - I know of someone that stripped their front bolts as there is a good amount of factory thread-locker on those bolts.
