06-22-2021, 04:45 PM | #1 |
Drives: 14 Camaro SS 1LE Join Date: Feb 2019
Takeoff 9668/372 AP Front Brake Kit
Is anyone interested in a takeoff CP9668/372 Gen 6 Camaro front brake kit?
https://www.essexparts.com/ap-racing...mm-gen6-camaro We may have a kit from a Gen 6 ZL1 that will be upgrading to a larger kit later in the year. |
06-22-2021, 05:33 PM | #2 |
Drives: 2018 Torch Red SS 1LE with Whipple Join Date: Jul 2018
Sent PM
2018 Torch Red SS 1LE, Whipple supercharger, custom tune, Rotofab CAI, ZL1 duckbill spoiler
06-23-2021, 01:21 AM | #3 |
Drives: 2019 Camaro Z-28 Join Date: Jul 2010
wheel clearance question
Currently I have a 2018 ZL1 brake setup on my SS 1LE. I am running 18 inch wheels (APEX EC7 18 x 11 ET25) and with the stocK ZL1 setup I BARELY clear the caliber now.
MY question is , if I wanted to assure myself of no clearance issues using your brake system, what is the largest rotor/caliber setup I could utilize. If I push any distance further OUTWARD towards the wheel compared to the stock setup then that would be a NO GO. In checking rotor specs of stock zl1 they are 390MM in diameter the same as yours (front rotor) but IF for some reason YOUR caliber sticks further out than the stock caliber than that could cause an issue with the 18 inch wheels. THANKS!!!
2019 SS 1LE BIG NA A10 Eagles Canyon Raceway 2.7 CCW Below https://youtu.be/c9M5UHDftcA 4-15-23 at SCCA TT U1 Class MEGA Thread on THIS car: https://www.camaro6.com/forums/showthread.php?t=602092 Retired Cars BELOW: 1973 Camaro, 1969 Camaro, 1969 Camaro SS RS 2010 Camaro SS with 1000HP F1R, 2019 ZL1 1LE A10 Last edited by sr71bb; 06-23-2021 at 01:40 AM. |
06-23-2021, 07:45 AM | #4 | |
They confirm that most apex 18" wheels fit under a 20 offset, they say that the ET35 wheels need a spacer in the front. They have a template that you can print and cut out, you pull a wheel off and throw the template on the back side of the wheel. It will show you if you have caliper clearance in your particular setup. https://www.essexparts.com/ap-racing...mm-gen6-camaro (wheel fitment tab at the bototm) |
