Old 06-21-2021, 08:58 PM   #1
clg82
Drives: 2020 Camaro ZL1
What mode for 1/4 mile
Hey everyone, what mode are you putting your A10 ZL1 in for 1/4 mile racing? Is “race” mode the correct for taking full advantage of all the available HP? What do you use for roll racing?
Old 06-21-2021, 09:03 PM   #2
gtfoxy
Drives: '21 Wild Cherry ZL1
Interested in others input as well. I used Race & Touring suspension recently. I did notice it short-shifting 1st at 5,500.
With some real stickies maybe turn everything off, which I don’t know how to do off the top of my head, which may be the way to go.
For a roll race if you don’t feel it reeling it back then it’s probably giving you near max power.
Old 06-21-2021, 09:06 PM   #3
CW3SF
CW3SF's Avatar
Drives: 2019 Chevy Camaro ZL1 M6
Here’s some data for you. I tested each mode on a dyno. Track-Race and Sport-Competition made exactly the same rwhp and Touring with nannies off only made 5rwhp less. Shifting is probably changed on the A10 in different modes but I can’t speak to that.
CW3SF is offline   Reply With Quote
Old 06-21-2021, 09:08 PM   #4
crosive
Drives: 18 zl1
I don't think it's so much any power being pulled or lost, but the load of the different suspension modes and traction.
traction on a dyno and traction on the street are diametrically different.
crosive is offline   Reply With Quote
Old 06-21-2021, 09:09 PM   #5
CW3SF
CW3SF's Avatar
As I said, just some data.
Old 06-21-2021, 09:13 PM   #6
gtfoxy
Dyno racing aside, I’ve had many decades of real world drag racing & I tried Track, Sport & Touring suspension modes. Touring posited the best MPH with the least wheel spin & felt the best. Track posted the lowest MPH with sport in the middle. All modes short shifted 1st gear.
Sometimes less is more when it comes to low end power production. Think of turbo cars ramping up boost vs MPH.
Old 06-21-2021, 09:17 PM   #7
dbs1
Drives: 2017 ZL1
Nice data share. Thanks
dbs1 is offline   Reply With Quote
Old 06-21-2021, 09:25 PM   #8
clg82
Hmm interesting analysis! I thought it pulled timing in all modes except track
Old 06-21-2021, 09:28 PM   #9
JasonGofast
Used to own a ZL1
Drives: '16 Z06
For dig racing Tour has the best weight transfer. Launch control should not be used for the best times at the strip.
So Tour + holding down traction control button will yield the best time.
For roll racing I assume the same to be true.
If you're doing any of this on the street I recommend either using Track - Sport 2 or Track - Race. This gives you some protection on an unprepped surface.
JasonGofast is offline   Reply With Quote
Old 06-21-2021, 11:41 PM   #10
gtfoxy
Suspension & hook is where you will see gains in 60’. Every tenth there is worth 2-3 x’s tenths & increased mph in the 1/4. MPH increases, as a relative function, because you are accelerating rather than wasting forward momentum spinning the tires, even if for a second or so.
Old 06-22-2021, 06:05 AM   #11
2018ZL1
2018ZL1's Avatar
Drives: 2018 ZL1 A10 NFG 2019 COPO 350 SC
Touring mode has been the best for my car 1.42 60 foot
2019 COPO #32
350 SC
8.25 167MPH
2018 ZL1-NFG-A10
388CI L8T
9.32 147MPH
2018ZL1 is offline   Reply With Quote
Old 06-22-2021, 11:33 AM   #12
Future1LEa10
Drives: 2021 Camaro 1LE
From what I hear its track mode, with suspension in tour mode.
Future1LEa10 is offline   Reply With Quote
Old 06-22-2021, 05:58 PM   #13
MartinLe
MartinLe's Avatar
Drives: 2017 Chevrolet Camaro ZL1 M6
I have not had my car at the strip, yet. I run my car in sport mode with the suspension set through info screen to touring. When I double tap the traction control and get to comp mode, my car gets violent and feels completely without reins nor any kind of power modulation.
JRE Terminator Rough Idle Cam
Magnuson 2650 - 15% lower, 90mm upper
FIC+30%
DSX Flex fuel/Low side
NW 103mm TB/Roto-Fab CAI
Monster S Series
Elite E2-X
2" TSP LT's
BMR:BK063, BK060,TCA061, UTCA060, UTCA063
Weld Beadlocks/17" NT5R2
MartinLe is offline   Reply With Quote
Old 06-22-2021, 08:20 PM   #14
gtfoxy
Yes, that’s what you do.
You need to be in Track to access the comp modes, launch control & your line lock.
