![]() Drives: 2022 ZL1 1LE Join Date: Apr 2019
PTM Discussion
So I've got about 18 track sessions on the 1LE now. Working my way through Sport mode to PTM Sport 1 and now I'm using PTM Sport 2 comfortably. Slowly the lap times are coming down and now looking for more power on exits. My question is what am I looking to expect from transitioning from PTM Sport 2 to RACE? Is there a big difference in the amount of power available to me, and what does this do in real life to traction management and stability control?
Hoping to tap into you guys that have had extensive track time and others that have systematically transioned between settings. |
2019 ZL1 1LE MY GOON
Drives: 1980 Z28 Big Red. Join Date: Dec 2018
I would suggest you go to the 1LE section and talk to Trackclub. He seems to have extensive information on the PTM system. Good to see your getting it out on the track often👍
There's a 1LE section? Huh! Thanks
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '21 ZLE A10 Join Date: May 2012
My suggestion is based off personal experience and some expert opinion from the actual engineers. PTM Sport 1 is great and not slow...stabilitrak is still enabled. PTM Sport 2 has stabilitrak off and thresholds are slightly higher for traction control interaction/intervention. PTM Race is similar to Sport 2 but made specifically for fresh tires or super sticky slicks/equivalent. I have spun my '17 ZL1 in Sport 1 on cold tires so PTM isn't perfect or a force field. Nothing can help a super sloppy input or other mistake...I've made plenty of mistakes. Track Club has a wonderful chart to further explain the differences in a "PTM modes demystified" sticky.
Petro-sexual
There's also what might be called a "certain way to drive" in these modes. I don't recall where I read this, but I think it was an engineer that talked about when and how to apply power for these modes. It almost didn't seem, what I'd call logical (though - I wouldn't say what I call logical has any base in reality), so it was interesting to see the logic that was used for these modes to dole-out the power. If I can find it, I'll post.
![]() ![]() ![]() ![]() Drives: 2018 Hyper Blue ZL1 1LE Join Date: Dec 2018
PTM Race has really incredible capabilities in my opinion, as long as you wait until you have apexed a turn you can go full throttle with confidence, but the key is knowing where the apex is--if you're inexperienced and/or wrong it can get you into trouble. It's a real advantage vs other high HP cars that dont have it. The handling issues I have since getting comfortable with Race mode are not due to a failure with PTM, it's always something that happens prior to hitting the apex or too much speed and bad steering input.
Once you get the hang of it, you can expect much faster lap times using PTM Race, but the fastest laps will come if you get really good and turn everything full off. I don't do this, but have ridden as a passenger while a great driver lapped my car in this mode and it takes a lot of skill. I turn it off on the skid-pad at Willow Springs and I'm getting better. |
#7 |
![]() ![]() ![]() ![]() ![]() Drives: 2023 CT5 Blackwing, 2025 C8 Z07 Join Date: Sep 2016
2017 HBM SS 1LE
Sold 2023 Wave Metallic CT5-V Blackwing M6 2025 Hysteria Purple C8 Z07 |
#8 | ||
Petro-sexual
#9 | |
#10 |
![]() Drives: 2021 1SS 1LE Join Date: Nov 2020
One of my goals this summer is to run all the modes at a trackday with AIM data and see what they do. I have only run the car with everything off at this point and it will be interesting to see how each mode works and reconciled with the data.
Ken |
