06-20-2021, 10:53 AM | #1 |
Drives: 2015 Camaro 2SS 1LE Join Date: Nov 2014
Head Gasket Orientation
EDIT: Pointless question, they are symmetrical.
1/12th of a turn is all I need.
06-20-2021, 01:39 PM | #2 |
Drives: 2012 Chevrolet Camaro l99 Join Date: Aug 2020
That's ok your just talking out loud and sometimes that's what it takes.
DSS FX Forged Pistons, Eagle ESP L19 Forged Rods, ARP Head and Main Studs, TSP PRC 260 CNC Ported Heads milled .030, Cometic .040 Head Gaskets, GPI SS3 VVT Camshaft, GM Performance Racing Lifters, CHE Trunnions , Molly Pushrods, Melling 10355HV Oil Pump, Cold Air Inductions CAI, Fast LSXR Intake Manifold, Nick Williams 103 TB, TSP 1 7/8" Longtubes with 3" TSP Exhaust, ZL1 Fuel Pump, Mishimoto Radiator, Mishimoto Oil Cooler, Tru Cool 40k Tranny Cooler, 3600 Circle D Converter, Fluid Dynamics Balancer
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817 |
06-21-2021, 01:06 PM | #3 |
Drives: 2015 1LE Join Date: Oct 2015
Just put the FRONT on the front of the motor and you are done, dont over think it
2015 1LE, TSP 225/236 113+3, VMAX Throttle Body, CAI with race scoop, GPI Ported Intake, Land Speed Stage 2 Heads, 1-7/8 headers, NPP exhaust, 25% Fluidampr, LT1-S Monster Clutch, 485 RWHP & 444 TQ
06-21-2021, 02:40 PM | #4 |
Drives: 2013 1SS 1LE Join Date: Jun 2016
What he said ^^^
2013 1le- Katech 416 short block, TSP custom grind cam, LOD intake, cnc heads by F.ED., Nick William's 102mm T.B., CORN fed, Pedders coilovers. Performance street alingnment by Justin at Lake Country Alignment and dyno tune by Late Model Throttle.
603 h.p. 495 ft lbs tq. |
10-30-2022, 09:08 AM | #5 |
2&THEHIT
Drives: 5th Gen Camaro; 5th Gen Ram 3500 Join Date: Mar 2018
Old thread, but not too old
... Anyone know why it matters? Does "front" mean front of the engine or front of the gasket? There's only one set of jacket water holes. Do they go to the rear of the engine? |
10-30-2022, 01:41 PM | #6 |
Drives: 2015 Summit White 2SS 1LE Join Date: Feb 2012
The gasket is designed to help direct coolant flow correctly.
The front coolant passages are closed off for the most part so that more coolant will be directed towards the back of the block so to cool the rear cylinders. If the gaskets are installed backwards most of the coolant flow will be mostly in the front of the block and cylinder heads causing heat issues for the rear cylinders.
Retired wanna be cylinder head porter
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter Totalled: 2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X |
10-30-2022, 08:34 PM | #7 |
2&THEHIT
That's what I thought Bo. Thanks!
