Old 06-19-2021, 04:36 AM   #1
Bumblebee50th
Drives: Chevy Camaro ss
My car pulls to the left when under a load
Yea my 6th gen when I increase speed or accurate it pulls to the left every time
Trying to figure this out … I’ve checked over the rear suspension didn’t find anything wrong but I can’t rule out anything any help would be appreciated
And it does it at light accusations…… when coasting stopping the car goes straight no pulling then…. Turning seem normal
Bumblebee50th is offline   Reply With Quote
Old 06-19-2021, 07:19 AM   #2
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
I’d guess alignment is off.
Old 06-19-2021, 07:53 AM   #3
Mike Aruba
Mike Aruba's Avatar
Drives: 2016 2SS
Might sound a bit stupid, but did you check your tire pressures?
Mike Aruba is offline   Reply With Quote
Old 06-19-2021, 12:46 PM   #4
Alpha1BC
Alpha1BC's Avatar
Drives: 2017 1SS 1LE
Ditto, check tire pressures and alignment. I'd also check stabilizer bars and links to make sure everything is tight there. Acceleration causes the body to roll and uneven loading between L and R sides from engine torque, unlike coasting and braking. It's likely alignment and/or tire pressures are off just enough to not be noticeable except for accelerating.
2017 SS 1LE.
Alpha1BC is offline   Reply With Quote
Old 06-19-2021, 03:27 PM   #5
Bumblebee50th
Well I switched back tires sides and now it goes right so it in the tires they both have 34psi but I think I found the problem one of my new ps4 has code M01 and the other has NA0 code
