Old 06-17-2021, 01:31 PM   #1
OniCamaro
Drives: Camaro V6 2017
Stubborn adhesive removal
I took out a paint protection film from a section on my rear bumper, the part that is slanted upwards. This had an emblem on it and it seems like the person who installed the PPF, stuck the emblem on them with some permanent adhesive. After taking off the PPF, I'm left with a very uneven surface of adhesive remnants(see tiny black dots all over) that I was not able to get off with goo gone and applying light-medium pressure with microfiber towel. Also the part that had emblems, have extra adhesive remants, which makes me think it somehow seeped in through the ppf and is going to be even harder to remove. Any advise to get rid of all this? I'm a detailing noob and kindof clueless how to deal with this without damaging paint.
OniCamaro is offline   Reply With Quote
Old 06-17-2021, 02:00 PM   #2
RamAir02
Shadow Gray '19 ZLE M6
RamAir02's Avatar
Drives: '19 ZL1 1LE M6
I would try a clay bar!
YouTube
Old 06-17-2021, 03:35 PM   #3
MANNAXMAN
MANNAXMAN's Avatar
x2 on the clay bar.
1996 Camaro Z28 with T-Tops (Sold 10.22.16)
1986 Camaro IROC-Z with T-Tops (Sold)
1961 Volkswagen Beetle with Sliding Ragtop Sunroof (2009-Present)
1964 Volkswagen Beetle with aftermarket Sliding Ragtop Sunroof (Sold)
Follow me on Instagram - @gen6_2ss_vert
MANNAXMAN is offline   Reply With Quote
Old 06-17-2021, 04:03 PM   #4
Spaceme1117
Spaceme1117's Avatar
Drives: 2017 Camaro SS, 2011 Corvette GS
3M General Purpose Adhesive Cleaner. You can usually find it at Oreilly's or Autozone usually in the touch up paint section.
Won't hurt the clear coat or paint.
Spaceme1117 is offline   Reply With Quote
Old 06-17-2021, 05:01 PM   #5
OniCamaro
Thanks guys. I realized the car is due for a clay bar treatment anyway so I'll get that done..
Old 06-17-2021, 11:14 PM   #6
KirkH
In my business, I use Turtle Wax Label and Sticker Remover and a plastic razor blade. Also, there are different strength Goo Gone products. I use the Auto Goo Gone and the Surface Prep Goo Gone. Sometimes I alternate between all 3 for tough adhesives.
Old 06-21-2021, 02:59 AM   #7
peteric
Drives: 2016 camaro
WD40 works great also. Just wash your car afterwards.
peteric is offline   Reply With Quote
Old 12-17-2024, 08:25 PM   #8
sklippi2018
Drives: 2021 ZL1 A10
I have somewhat the same issue. Darndest residue hard as heck to get off. Heat gun couldn't do it and neither goo gone even though I let it soak. Research shows WD40 and 3M Adhesive Remover are best and don't hurt paint. Also, DIY Bug Remover. I'll try the WD and 3M to see what happens.
Disregard the hole; previous owner put SS emblem on to hide it. Separate project so may just use touch-up paint to camouflage it for now because it'll run $2,400 to "really" fix it.
sklippi2018 is offline   Reply With Quote
Old 12-18-2024, 06:55 AM   #9
NashZL1
Drives: 2022 Camaro ZL1
3M Adhesive Remover or SEM Solve. Work great.
Randy in Nashville
2022 Chevrolet Camaro ZL1 A10
2020 Ford Mustang Shelby GT500
2020 Genesis G90 Ultimate
2018 Porsche 718 Cayman GTS
2019 Mercedes-Benz SL450
2017 Corvette Grand Sport A8
2024 Honda Civic Touring
1971 Datsun 240Z
NashZL1 is offline   Reply With Quote
Old 12-19-2024, 05:00 PM   #10
ctrlz
I think you have good recommendations regarding the adhesive residue.
As for the hole, try a hot glue gun for a temporary plug. Glue sticks are polypropylene and you should be able to shave it flush when cool or maybe nudge it while still warm. It should form a distorted shape on the back side which holds it in place. PP will take paint.
Old 12-22-2024, 10:57 PM   #11
sklippi2018
At this point I do not know what this is. I've taken y'alls advice and watched videos. I've tried: heating it, goo-gone, wd-40, 3m adhesive remover, and bug and tar remover and not one fleck of residue has come off. I've even used the plastic scraper while using each.
I did order a rubber wheel and it comes tomorrow. I'll give that a whirl. My hesitancy is that if none of the residue would come off it is really adhered to the paint and if I use the rubber wheel it may take paint off as well. We'll cross that bridge when we get to it ... I'll definitely be careful.
Old 12-31-2024, 06:26 PM   #12
sklippi2018
UPDATE- Rubber wheel
Well I used the rubber wheel and nothing happened.
Applied minimal pressure and not even a fleck of the adhesive came off. My detailer seems to think it is some kind of industrial super glue.
To repair the hole and repaint would run $1,400+ so at this point I'm gonna clean it up, use touch-up paint to "hide" the hole, and get the right sized emblem to cover it up.
Old 03-12-2025, 03:23 AM   #13
Val Walkinshaw
L8ap3x
Val Walkinshaw's Avatar
Drives: 2018 2SS 1LE
Hobbyist and professional detailer/paint correction specialist checking in:
3M adhesive remover (this shit is amazing)
https://a.co/d/cPXGroN
Stoners tar and sap remover (also fantastic adhesive remover) Well respected in the industry.
https://a.co/d/gGOYspV
Mineral spirits
(tractor supply, home Depot, Lowe's)
Do remember than any of these if left on for long periods (10 minutes or more/hours is NOT a fun time) or not washed off with a non ph neutral soap (dawn, alcohol or an APC (all purpose cleaner) is not recommended.
Plastic razor blade is also helpful.
I would recommend after adhesive removal that you wet sand the area to help determine the true extent of damage. 1000, 2000, 5000 grit. The a medium polish, fine polish to follow. If you have missing paint I would recommend also a well respected company that has 20+ years in business. Send them your VIN and paint code. The match will be closer to perfect than any human eye can detect.
Automotive Touchup
https://www.automotivetouchup.com/?g...saAvuBEALw_wcB
Automotive goo gone is weak. I do not recommend it.
"Manuals win hearts. Automatics win races."
2018 2SS 1LE HBM 6M
Val Walkinshaw is offline   Reply With Quote
