Old 06-12-2021, 01:44 PM   #1
Puddin
Ac issue
So now that the Texas heat has shown up I decided to turn on the ac and it worked for a little bit then shut off. I've noticed this morning when the ac compressor kicked on the fan did not come on with it but I still had cold ac as long as I was moving. Does this pretty much point to the fan being the culprit or can it be something else? Also the fan doesn't come on when it's up to temp either but my gauge on the dash never goes above the 11:00 position. Shouldn't it be overheating with no fan to help cool it down? I've changed fuse 52 and I'm going to replace K8 relay today to see if that fixes it. Any thoughts and suggestions are greatly appreciated as I've been racking my brain over this cooling system on this car.
Old 06-17-2021, 01:02 PM   #2
jimrhodes
Drives: chevrolet camaro
Damn, that sucks. Now it's the worst time to have problems with AC in your car. I hope you will fix that soon. Good luck
Don't forget to check assignment writing service for your next posts.
jimrhodes is offline   Reply With Quote
Old 06-23-2021, 12:32 AM   #3
peteric
Drives: 2016 camaro
Have you tried checking if there's power at the fans?
peteric is offline   Reply With Quote
Old 06-23-2021, 01:08 AM   #4
Puddin
Yeah it's fixed now. Put a new fan in and it fired right up and has been working since last Saturday. Wasn't too terrible replacing it either only took a couple hours.
