Old 06-11-2021, 02:06 PM   #1
PROMETHEUS
PROMETHEUS's Avatar
GYSC3Rs on closeout
Tirerack has the 325/30/19s on closeout. Just added the 305/30/20s as well. Only a $25+ difference between closeout price and regular price on these. I'm surprised, usually the closeout price is about half price. Here if you need them.
https://www.tirerack.com/tires/tires...omCompare1=yes
Forgot to mention, GY is also running a rebate of $75 for 4 and another $75 if you use GY CC, which runs to the end of June. Tirerack does accept GY CC as payment.
Old 06-11-2021, 03:17 PM   #2
LJS-ZLE
LJS-ZLE's Avatar
Drives: 2019 Camaro ZL1 1LE
Two less tires available now. Thanks for the heads-up.
LJS-ZLE is offline   Reply With Quote
Old 06-11-2021, 04:28 PM   #3
PROMETHEUS
PROMETHEUS's Avatar
Old 06-11-2021, 06:11 PM   #4
20Bluezl1
They are 2018 production, how long are the 3R shelf life?
Old 06-11-2021, 06:42 PM   #5
Camaro1973
Camaro1973's Avatar
Drives: 2019 ZL1
6+ years.
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90
Old 06-11-2021, 07:15 PM   #6
G61LE
G61LE's Avatar
Drives: 2019 Camaro ZL1 // 1LE
Got the last four. Thanks for the heads up.
G61LE is offline   Reply With Quote
Old 06-11-2021, 07:24 PM   #7
Mize442
Mize442's Avatar
Drives: Current driver AMC emlin X 5ltr.
Can we use the same size for the front?
Mize442 is offline   Reply With Quote
Old 06-11-2021, 07:43 PM   #8
Zl1+911
Drives: 997 GTS, ZL1 A10, ZLEM6, ZLEA10
I had asked the same question a while back and I did get confirmation from a couple of members that they have indeed run the back size on front without adverse effects
Zl1+911 is offline   Reply With Quote
Old 06-11-2021, 08:01 PM   #9
20Bluezl1
just ordered 2 I believe they have to have more because I don't see them sold out yet. Does anyone get there heat cycle?
Still have a set with there heat cycle and have 3 track days and look still new
Old 06-11-2021, 08:03 PM   #10
Badmojo
aka BeastZL1
Badmojo's Avatar
They are still showing stock and you'll get "old" stock, but newer than what they advertise. If you buy 4, you get a $75 rebate. I am over-flowing with tires, but if you are not......buy now.
2019 Camaro ZL1 1LE
Racing for ALS Youtube Link
Old 06-11-2021, 08:15 PM   #11
20Bluezl1
Have to look for fronts now.
Old 06-11-2021, 09:26 PM   #12
s.hammer
Drives: 2015 Z/28
Cheap ones are gone for now :(
s.hammer is offline   Reply With Quote
Old 06-12-2021, 04:19 AM   #13
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
I mounted 2 extra 325/30-19s on the front wheels and they look fine. At VIR now and will report my "feelings" after a session or two. I don't anticipate any issues.
Old 06-12-2021, 06:41 AM   #14
G61LE
G61LE's Avatar
How do I get the $75 rebate, do I have to register or send something in ?
