Old 06-08-2021, 06:42 PM   #1
Mike@SolerPerformanceLLC
Mike@SolerPerformanceLLC's Avatar
Drives: 2015 Corvette Stingray
Introducing Soler Perf. 103MM Throttle Body
Hello, everyone. Just wanted to introduce our latest addition to our lineup for the LTX, a much-needed "4th hitter". The result of almost two years of work, built from the ground up to compete and win. Brings a much-needed alternative to a limited, almost monopoly-like, market. Now you can have the best yet you do not have to pay the most.
Introducing Soler Performance 103MM throttle body for all the LTX's engines and more.
- At 1700+/-50 SCFM @ 20.4" Water, it flows like a 107mm TB but fits like a 103MM.
- Has all the goodies/features we have seen in our LT1/LT4/LT5, plus some new features, all unique to our throttle bodies.
- Designed with driveability in mind, it behaves like a stock TB when idling, composed when cruising, responsive when demanded, and a black hole available beyond that.
- Firm and balanced at WOT under boost and not a nightmare to tune at partial throttle. In fact, runs smoothly even on stock LT1's with the stock tune.
- Flexible bolt pattern to directly fit all LTX manifolds/superchargers (stock or custom), including the LT5 supercharger.
- We have also added a set of accessories (customizable if required) to ensure a perfect fit, sealing, and transitions.
- Made from materials equal or better than those used by the OEM. Fully machined for a better finish and repeatability.
- It is durable, strong, and stiff for its duty, yet light and stylish for your interior looks.
- Fully tested and approved by forum members.
- All this with a warranty, customer service, and technical support to be matched.
Mike@SolerPerformanceLLC is offline   Reply With Quote
Old 06-08-2021, 06:58 PM   #2
dbs1
Drives: 2017 ZL1
So Mike, what advantages or gains will I see if I add this along with a big gulp to replace the standard rotofab and TB I've already purchased from you that compliment my headers, lower pulley and e50 tune on my 2017 ZL1?
dbs1 is offline   Reply With Quote
Old 06-08-2021, 08:16 PM   #3
Z OH 6
Drives: 2021 Red Hot ZL1
Its certainly pretty.
Old 06-08-2021, 09:00 PM   #4
Chrome383Z
Chrome383Z's Avatar
Drives: 2019 Camaro 2SS
Outstanding! Looks good.
2019 Shock 2SS A10. 2650@10psi/LPE HPFP/XDI+30/LT4 LPFP+JMS/Soler 95mm/Rotofab, E65, CSP 2” Headers/GESI GenII Cats. MM Wild/GM SG3 suspension/1LE Brakes, Velgen VF5 Wheels/GY SC3. JRE Tuned.
Chrome383Z is offline   Reply With Quote
Old 06-08-2021, 09:08 PM   #5
RamAir02
Shadow Gray '19 ZLE M6
RamAir02's Avatar
Drives: '19 ZL1 1LE M6
What a beauty! Awesome
YouTube
Old 06-08-2021, 10:13 PM   #6
Aaron07
Aaron07's Avatar
Drives: 2017 2SS F1FTY
Direct bolt on to the MSD manifold?
Aaron07 is offline   Reply With Quote
Old 06-08-2021, 10:46 PM   #7
Brudda*Termite
Brudda*Termite's Avatar
Drives: 2017 Camaro 2SS
Second that, looks like the holes are oblong enough, but please advise!
Gary
2017 2SS A8 White, Bolt-Ons, Prayed Upon
Brudda*Termite is offline   Reply With Quote
Old 06-10-2021, 07:11 PM   #8
Can't really promise any numbers for any specific setup. However, there's plenty of info out there about previous 103's and this one is an improvement over those.
If you are near or greater than 800 engine hp, I'd recommend you strongly consider it.
If you are under that, and what you have is our LT5 TB, you are fine.
If you are under that, and what you have is our LT4 TB, you might want to consider our LT5 TB or even this one, so you won't need another throttle body later on.
Old 06-10-2021, 07:25 PM   #9
Yes, these two are a great match to have.
Old 06-10-2021, 07:30 PM   #10
It is a dual-purpose hole pattern, the innermost part of them is for a direct fit to the MSD and all our LT1/2/4 manifolds/superchargers, or aftermarket superchargers too. The outermost is for a direct fit to the LT5 (ZR1) supercharger.
Old 09-05-2021, 11:37 AM   #11
Wvdirtroads
Drives: Silverado
Does this throttle body come with an o ring plate that will seal against a ported LT4 supercharger, or would it still require sealant?
Wvdirtroads is offline   Reply With Quote
Old 09-06-2021, 08:02 AM   #12
Brudda*Termite
Thanks Mike, looks like a great product! I have the Soler LT5 ported TB now and it's probably enough but that big mama is tempting me, haha...
Gary
Old 09-06-2021, 02:48 PM   #13
FlukeSS
FlukeSS's Avatar
Drives: 2020 Camaro 2SS A10
Forgive my ignorance, but I was under the impression bottle necking determines the output. So if a 103mm TB paired with MSD's 103mm intake how exactly does the 103mm TB perform like a 107mm?
I mean is there some special feature this TB has over say: Nick Williams 103mm TB?
Old 09-06-2021, 09:12 PM   #14
BlackbeastSS2
BlackbeastSS2's Avatar
Drives: 2019 Camaro 1LE Shock Candy
Kind of like saying to your GF that your six inch Johnson performance like a 7 inch Johnson and yes GF there is a special feature hidden inside.
LT4 1.7 Supercharger snout ported & 100% Meth
103 Katech TB, KATECH Custom Heads, DSX In-line fuel
TSP Headers, Spec P Super Twin Clutch, TSP EL C7 CAM
Diamond Piston & Manley Rods, Roto Fab Big Gulp
BTR Push Rods,LS7 Lifters, ARP, FI Chiller, Kirkey Seats
SJM Line Lock, Hurst Pistol Grip. 747/739 RWHP street tune - 821/794 RWHP track tune 101 octane.
2014 Mini Cooper countryman S All4 M6 daily driver
BlackbeastSS2 is offline   Reply With Quote
