![]() Drives: 2020 Chevrolet Camaro 2SS/1LE Join Date: May 2020
Wont shift into 6th
2020 2ss 1le 6 speed manual Track mode wouldn't shift into 6th gear. Less Than 300 miles on OD
I wasn't going that fast 55 mph in 5th and went to shift into 6th it wouldn't go into 6th gear. Pulled straight back from 5th like there was no "Gate" for 6th. I didn't check any other modes. Just seemed odd. unless i wasn't going fast enough for 6th ? No 6th in track mode? Just seemed odd, before I go to dealer and they point out I'm an idiot, anyone have this problem ?? Update it goes int 6th I'm stupid 6/7/21
2020 Camaro 2SS 1LE
1968 Camaro AzLast edited by Azmedian; 06-07-2021 at 04:03 PM. Reason: Additional info |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 19 Chevrolet Camaro 2SS 1LE Shock Join Date: Apr 2020
The only electronic restriction in the TR-6060 is the 1-4 CAGS, AKA skip shift. You can shift into 6th any time.
Personally, I think 6th gear is fine as long as you are above 50 MPH on flat ground. Kind of odd that you can't shift into 6th. Usually, people can have some issue shifting into 2nd when the transmission is cold. Have you tried shifting with the car off?
Current:
2019 Chevrolet Camaro 2SS 1LE M6 Shock GM Performance Intake and that's it, because driver mods before car mods Past: 2009 Mazda RX-8 GT M6 Velocity Red Mica (Sold) 2015 Chevrolet Corvette Z51 2LT M7 Velocity Yellow Tintcoat (Flood totaled) |
#3 | |
Ill try it tomorrow with car off see what happens
2020 Camaro 2SS 1LE
1968 Camaro Az |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 23 ZL1 A10 Rapid Blue Join Date: Aug 2020
You shouldn't be locked out of 6th in any mode. 6th at 55 is too low in RPM but that's IMVHO, but still shouldn't be locked out.
![]() Drives: 2018 Camaro ZL1 Join Date: Feb 2019
take it to the dealer...
2018 ZL1 - Daily driver
![]() 2018 Mercedes Benz AMG GTS 2017 C7 Grand Sport - Stage two Edelbrock |
On flat ground, you are perfectly fine. IMO anything above 1100 RPM on flat surface is okay. Small block has good enough low-end torque for that to work.
Current:
| Tags |
| 1le 2ss, 6 speed manual |
