![]() Drives: 2021 LT1 Join Date: Jun 2021
I have a 2021 LT1 Camaro with the stock single tip exhausts (non-NPP exhaust). I am thinking about installing a Borla Axleback setup eventually down the line, but because money is a bit tight, I wanted to find a way to make the car sound better.
Everyone claims this is somewhat achievable by pulling the #51 fuse in their SS models with the NPP exhaust. My curiosity led me to the fusebox under the hood of my car. I noticed that there was a fuse in the #51 spot and using the manual I identified it as "Exhaust Valve PTSQ". Will pulling this fuse have any effect on the sound of my car considering it does not have the NPP option. Genuinely curious, as I have not seen anyone make a post about it anywhere. Any tips or advice would be greatly appreciated. |
![]() ![]() ![]() Drives: 2017 Silverado/2017 ZL1 Join Date: Aug 2019
Without npp, no difference.
Kyrac
Drives: 2018 2SS A8 Join Date: Feb 2015
Just like Jaxcam02 said, no difference without the NPP... I did the fuse pull almost immediately after I bought car cause it wasn't loud enough, still wasn't loud enough so I straight piped mine back with a MBRP system and now it's loud and proud!!!
#4 | |
2020 Shadow Gray 2SS
After delivery: - GMP CAI, GMP Black Strut Tower Brace, MRR017 1LE Wheels, SS Armrest, Black Fuel Door, Stainless Pedals, SS Wheel Caps, GM Splash Guards, DD Smoked LED Markers, Smoked Rear Reflectors, Mishimoto Catch Can, Xpel PPF-Full Front & Rockers, 35% Tint, CeramicPro coated, RST Stainless Brake Lines, Castrol SRF, MSD Plug Wires, Mamo V3 Ported TB Left: My "fun" ride (455 HP). Right: My "work" ride (52,000 HP): a Gulfstream G600. One's top speed is 180 Mph, the other, 620 Mph. BOTH AWESOME to operate... |
#5 | |
Drives: 2016 Camaro 2SS Join Date: Sep 2020
Straight pipe might be the way to go. I live in a sub division so that's a no go. Thinking about Borla though. Mine was used to it came with the NPP. Personlly if I were ordering a Camaro I would not spend the extra cash on NPP because I'd just put my own aftermarket on anyway. I mean others with Mustangs sound much louder than me and drive by at night. If they don't like the sound of my SS then tough sh**. They don't pay my car payment! |
![]() ![]() Drives: 2021 LT1 6spd Join Date: Nov 2020
I went with a Corsa axle back, sounds mean - very much musclecar-ish. The Non-NPP version would be the Corsa xtreme. Borla ATAK ro Corsa Xtreme will likely scratch your itch.
the Stainless Works versions and MBRP make fine sounding products as well.
Current: 2021 LT1 Camaro, 6spd, Crush, Corsa NPP, GMPP CAI, Soler Performance Throttle controller
Previous: 1997 V6 Camaro, 5spd, Black |
#7 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 23 ZL1 A10 Rapid Blue Join Date: Aug 2020
#8 |
![]() ![]() Drives: 2017 Camaro SS, 2011 Corvette GS Join Date: Feb 2019
After I installed a Rotofab intake, I found that my 2017 SS had a better, deeper exhaust note. Its not huge but it is definitely noticeable.
My car has the NPP exhaust which I love. Maybe there is a way you could retrofit a used NPP to your car? |
#9 | |
![]() ![]() ![]() Drives: 2020 LT1 M6 Join Date: Jan 2016
I have zero regrets, the car sounds perfect to me now. I was told by many people it would drone all the time and sound like crap or like an old truck with open headers, it does not. The car is quiet at idle, cruising, and part throttle, however, cold start and wide open throttle are "wake the dead" loud. Also, a nice side effect of the muffler delete was about 35 lbs in weight reduction. I will say, my car is manual, so I probably don't hear drone as my camaro barely spends any time in the rpm range where the automatic guys say they hear drone. I love the muffler delete and I will probably keep it till the warranty runs out when I can do longtube headers, offroad mid pipes and throw the stock non npp muffler back on. Whatever you decide, good luck, there are plenty of used axlebacks and catbacks out there, just know they are priced aggressively. Staying with a single tip exhaust will also save you some money. |
#10 | |
![]() Drives: Chevy Camaro Join Date: Apr 2020
#11 |
#12 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 17 SS 1LE Join Date: Dec 2015
An efficient way to make the car sound louder is to pull the trunk liner and fold down or remove the rear seatback. I was driving like that mid stereo install and it was quite throaty.
| Tags |
| 6.2 v8, exhaust, lt1, npp fuse pull guide exhaust, super sport |
