Old 05-30-2021, 12:38 PM   #1
Crush_ZL1
Crush_ZL1's Avatar
Drives: 2019 Camaro ZL1
Full bolt on power numbers?
Hey Everyone,
Just in before my zl1 goes under the knife next week. Getting a solid amount of mods. What do you guys think she will put down number wise? Really hoping to crack 700! What do you guys think it’ll make/run in 1/4 once it’s back?
5” intake
Ported throttle body
9.17 lower
Dual nozzle alky methanol system
E85
Kooks 2” Headers and 3” mids
MM wild
ATI damper
17” Hoosier DBR’s
Crush_ZL1 is offline   Reply With Quote
Old 05-30-2021, 12:42 PM   #2
Ron_Robinson1
Ron_Robinson1's Avatar
Drives: A Static line to a pack tray & ZL1
Send a message via AIM to Ron_Robinson1
What shop you using?
2017 ZL1 A10: 8.84 @ 156 PB
2017 ZL1 A10: Previously FBO 756/761 (9.6 @ 143 1/4)
SOLD-2013 ZL1 M6:BTR,LTs,IDs,ATI,RotoFab10.84@129
SOLD-2011 SS M6: Blower, Cam, Alky, LTs.
Ron_Robinson1 is offline   Reply With Quote
Old 05-30-2021, 12:45 PM   #3
Crush_ZL1
Crush_ZL1's Avatar
Originally Posted by Ron_Robinson1 View Post
What shop you using.
LMP in Maryland, really good shop
Old 05-30-2021, 12:53 PM   #4
Crush_ZL1
Crush_ZL1's Avatar
Will update as well, should be getting some real world ET’s by end of June
Old 05-30-2021, 01:17 PM   #5
Ron_Robinson1
Man your right Long Island with JTM. Good luck with your build.
Old 05-30-2021, 03:59 PM   #6
Camaro1973
Camaro1973's Avatar
Drives: 2019 ZL1
Ya why didn't you goto JTM? You'll probably be at that power level depending on what/how much meth your your injecting.
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90
Old 05-31-2021, 07:32 AM   #7
2018ZL1
2018ZL1's Avatar
Drives: 2018 ZL1 A10 NFG 2019 COPO 350 SC
I would say 700RWHP with this! Alec is a good guy! You wont be disappointed! Probably high 9's in the 1/4 @ 138MPH?
2019 COPO #32
350 SC
8.25 167MPH
2018 ZL1-NFG-A10
388CI L8T
9.32 147MPH
2018ZL1 is offline   Reply With Quote
Old 05-31-2021, 07:42 AM   #8
Ron_Robinson1
Are they doing a trans tune as well or just ecm?
So many variables to guessing power #s. Off hand I say 675-700 depending on the dyno and how much meth & e85 you can feed if.
Also track numbers, I would think it will crack 9s.
Old 05-31-2021, 03:15 PM   #9
Crush_ZL1
Crush_ZL1's Avatar
Should probably update location. I will be moving to Maryland within next few months so figured it would be perfect to have my shop somewhere close, plus they are a great shop.
Old 05-31-2021, 03:17 PM   #10
Crush_ZL1
Crush_ZL1's Avatar
They will be doing the transmission tune as well. Less concerned about numbers, more concerned about cutting good times obviously lol
Old 05-31-2021, 03:19 PM   #11
Crush_ZL1
Crush_ZL1's Avatar
We will see within the next few weeks. Will update as soon as it’s wrapped up, can’t wait!! As long as it’s basement 10s I’ll be thrilled
Old 05-31-2021, 06:15 PM   #12
NOVAtwinLS3
NOVAtwinLS3's Avatar
Drives: 2018 ZL1
You have tires set up already or planning on going to drag pack? Definitely have to feather it on stock GY’s, my 60’ can attest to that.
CSP 755 Package. 2” headers, Kong ported blower, NW103mm TB, RF Big Gulp, Mighty Mouse catch can.
630rwhp/660rwtq.
NOVAtwinLS3 is offline   Reply With Quote
Old 05-31-2021, 06:54 PM   #13
BAllgyer
BAllgyer's Avatar
Drives: 2021 Camaro ZL1 1LE
re: Full bolt on power numbers?
Is GM even supporting the Drag Pack update anymore?
I tried to get it also, but was told it's currently being updated with no known ETA for release again.
2021 White ZLE
BAllgyer is offline   Reply With Quote
Old 05-31-2021, 09:33 PM   #14
Crush_ZL1
Crush_ZL1's Avatar
Yes sir, I have 28x10.5r17 Hoosier drag bracket radials with 17 inch forgestar d5’s for the rear. Unfortunately ET street R’s were crazy back ordered and did not want to wait
