Old 05-29-2021, 06:03 PM   #1
KILLA BEE
Black lightning
KILLA BEE's Avatar
Drives: 2021 ZL1 1LE A10
315 30s
You guys do no if you upgrade to a 315 30 20 you don't have to worry about the harness relocation right. I see some doing it and be like whyyyyyyyyy. The 1les do not HAVE THAT PROBLEM
[ 2021 Camaro ZLE 10 speed
KILLA BEE is offline   Reply With Quote
Old 05-29-2021, 07:06 PM   #2
Justcruising
Justcruising's Avatar
Drives: 2019 Chevrolet Camaro 2SS A10
I will investigate it as I just bought a set of tires and purchased 315/30 for the rear
Justcruising is offline   Reply With Quote
Old 05-29-2021, 08:14 PM   #3
MSU120
Drives: 2018 1SS 1LE
I just added 315/30s this past week and I moved the harness.
2018 SS 1LE—707rwhp, 615rwtq
2009 Pontiac G8 GT—605rwhp, SOLD
MSU120 is offline   Reply With Quote
Old 05-30-2021, 12:39 PM   #4
Justcruising
I just put 315/30 on and can still put my hand between the tire and fender liner so i think its good to go without having to move the harness
Old 05-30-2021, 01:07 PM   #5
Scargoes
Scargoes's Avatar
Drives: '18 Hyper Blue 2SS1LE '20 Crush RSR
I run 305/30R19 and it rubbed thru the fender liner. I see it also rubbing on the harness, I need to do the relocation. I am running -2* rear camber.
2018 Hyper Blue Metallic 2SS 1LE with Nav, PDR, and track alignment
1:28.95 Willow Springs Big Track
Scargoes is offline   Reply With Quote
Old 05-30-2021, 01:09 PM   #6
Vaska
Drives: On Hiatus
Completely relevant post considering we are talking about stock 20” wheels, ride height and alignment.
Vaska is offline   Reply With Quote
Old 05-30-2021, 07:54 PM   #7
Scargoes
Scargoes's Avatar
Guess we aren't seeing the same post because in the post I see it just mentions 315 30. Nothing about stock 20" wheels, stock ride height, nor stock alignment.
Old 05-30-2021, 11:14 PM   #8
Vtor_ZL1
Who Needs to KNOW?
Vtor_ZL1's Avatar
Drives: 18 ZLE
19 vs 20 makes a difference.
19".. no issues, 325/30R19.
20".. you're going to eat fender liner and wiring harness IF you drive it hard enough. If you're granny shifting and double clutching and hard parking.. you're safe.
ing for grip.
http://www.motorsportsne.com/
Old 05-31-2021, 08:59 AM   #9
MSU120
Agreed.
Old 05-31-2021, 09:12 AM   #10
GTASS1LE
Drives: Chevrolet Camaro SS
Wheel offset on the 19's is kind of important also.
GTASS1LE is offline   Reply With Quote
Old 06-03-2021, 02:29 PM   #11
Vaska
Drives: On Hiatus
You do realize stock 1LE wheels are 20” right?
Old 06-03-2021, 02:42 PM   #12
MatthewAMEL
MatthewAMEL's Avatar
Turbo/V6/SS 1LE wheels are 20"
ZL1 1LE are 19"
OP wasn't terribly clear in his initial post which is why some of the responses are what they are.
And unless the 2021 has that harness relocated from the factory, you absolutely need to move it if you go wider on the 20".
2017 HBM SS 1LE
Sold
2023 Wave Metallic
CT5-V Blackwing M6
2025 Hysteria Purple
C8 Z07
Old 06-04-2021, 09:12 AM   #13
KILLA BEE
Black lightning
KILLA BEE's Avatar
Ya stock wheels size only no 19s etc
Old 06-04-2021, 09:17 AM   #14
KILLA BEE
Black lightning
KILLA BEE's Avatar
Yes we are stock wheels ONLY, if you changed anything like lowering it etc then that could be different. Biut with stock you do NOT unless you just wanna do extra work that's not needed
