Old 05-28-2021, 08:44 AM   #1
Blackkaz04
Drives: 2006 Z06
HELP. What is this wire
Guys, at the exhaust shop doing a magnaflow x-pipe muffler
What is this wire that’s running across the bottom metal cross brace??
Blackkaz04 is offline   Reply With Quote
Old 05-28-2021, 08:46 AM   #2
Wuiquen
Wuiquen's Avatar
Drives: 2018 Hot Red ZL1
Originally Posted by Blackkaz04 View Post
Attachment 1069354
Definitely aftermarket. That is not present in my ZLE.
Sent from my moto g(7) power using Tapatalk
Old 05-28-2021, 08:46 AM   #3
Blackkaz04
Drives: 2006 Z06
Having a hard time figuring out where to mount the muffler...tunnel is narrow!
Old 05-28-2021, 08:54 AM   #4
PROMETHEUS
PROMETHEUS's Avatar
I don't have any wires running across the bottom of mine, either. Follow it and see where it goes.
Old 05-28-2021, 08:54 AM   #5
Blackkaz04
Drives: 2006 Z06
Yea it looks like it goes back to where the NPP plugs are in the rear.
Old 05-28-2021, 09:21 AM   #6
Wuiquen
Wuiquen's Avatar
What does it connect to in the rear? Does it go into the trunk? If I had to take a wild guess, maybe someone is running power from the trunk into the car to power maybe lights or aftermarket accessories. Cut outs power? Did the car come with NPP stock?
Old 05-28-2021, 09:26 AM   #7
Vigilante375
Drives: 2018 Camaro ZL1
That isn't from the factory. Whomever installed that wire did a crap job.
Old 05-28-2021, 09:51 AM   #8
avalonandl
avalonandl's Avatar
Drives: 2019 ZL-1
Are those holes in the exhaust pipes before the X ?
Old 05-28-2021, 10:23 AM   #9
Blackkaz04
Drives: 2006 Z06
I traced it back to the NPP plug area. It’s not connected to anything. Must of had a different exhaust on it before the current magnaflow. (Which the factory side of the NPP harness is still there. First time having the car on a lift since I bought it last week.
Old 05-28-2021, 10:25 AM   #10
Blackkaz04
Drives: 2006 Z06
No holes in the exhaust. It did have a slight leak where the xpipe connected to the headers. Not anymore
Magnaflow x-pipe muffler almost in. Car has heads and cam with the LTs/no cats and some sort of magnaflow exhaust makes ear bleeding drone.
Hopefully this brings the crazy down a notch.
Old 05-28-2021, 10:27 AM   #11
Blackkaz04
Drives: 2006 Z06
Current cat-back installed...magnaflow something....guesses?
