Old 01-04-2010, 11:06 PM   #1
FenwickHockey65
General Motors Aficionado
FenwickHockey65's Avatar
GM Reveals 2011 Cadillac CTS-V Coupe!
Art And Science: Cadillac Premieres 2011 CTS-V Coupe
Link to article at GMInsideNews
Link to Press Release
1-5-10
o New CTS Coupe design combines with V-Series performance
o 556-hp (415-kW) supercharged 6.2L V-8
o Six-speed manual or six-speed automatic with paddle shift control
o Magnetic Ride Control and Brembo brakes
o New Saffron interior trim accent color
o On sale in early summer
DETROIT – Cadillac today announced the 2011 CTS-V Coupe, which debuts at the 2010 North American International Auto Show in Detroit. It combines the new CTS Coupe’s dramatic design with the 556-horsepower (415-kW) supercharged V-8 engine from the CTS-V sedan. The result is a luxury sports coupe aimed at driving enthusiasts.
“The CTS-V Coupe marries our most potent and sophisticated technology with our most dramatic production design,” said Bryan Nesbitt, Cadillac general manager. “This combination of visual and technical attributes is designed to create a very compelling choice for luxury sports car consumers.”
The CTS-V Coupe begins production this summer. Its suite of technical and performance elements includes Magnetic Ride Control, racing-bred Brembo brakes and an available automatic transmission with paddle-shift control.
The V-Series Coupe includes a unique grille that doubles the car’s air intake volume, an important enabler for its high-performance capabilities. It is also visually identified by a raised center section of the hood that provides clearance for the supercharger, as well as specific front and rear fascias. Like the CTS Coupe, its exhaust is centered inside the rear fascia, but with unique twin outlets. The car rolls on 19-inch cast aluminum wheels, available in either painted or polished finishes, and Michelin Pilot Sport 2 performance tires.
The CTS-V Coupe’s rear track is nearly an inch wider than the CTS-V Sport Sedan, adding to the car’s aggressive stance and enabling an extra measure of handling capability. The current CTS-V Sport Sedan has quickly established itself among the world’s highest performing luxury sedans, becoming the first production four-door on street tires to break the legendary 8-minute barrier at Germany’s famed Nürburgring. The new V-Series Coupe’s sleeker shape and slightly lower mass ensure a similarly high level of performance.
Inside, the 2+2 cabin combines performance and luxury. A new Saffron interior trim color is offered, with contrasting microfiber seat inserts and stitching on the upper trim areas.
Form follows function
The CTS-V Coupe’s design is a clear visual statement of the technical precision and performance intent of the car.
The Coupe has the same wheelbase as the CTS-V Sport Sedan, but its overall height is about two inches (51 mm) lower and its overall length is two inches (51 mm) shorter. The two models share only the instrument panel, console, headlamps, front fenders and grille.
Key design features include:
* Classic hardtop styling, with no conventional B-pillar
* Touch-pad operation for the doors removes the need for conventional door handles
* Faster windshield angle (62.3 degrees) and a nearly horizontal backglass enable an aerodynamic profile
* Signature vertical lighting, highlighted with LED light pipes
* Signature center high-mounted stop lamp functions as a rear spoiler
* Aerodynamic roof-mounted antenna for OnStar and XM Satellite Radio
Supercharged powertrain
The CTS-V Coupe employs the LSA 6.2L supercharged V-8 engine also found on the CTS-V Sport Sedan. Rated at 556 horsepower (415 kW) and 551 lb.-ft. of torque (747 Nm), it is the most powerful engine offered in Cadillac’s history and propels the CTS-V Coupe from 0-60 mph in 3.9 seconds.
The LSA engine features an intercooled Eaton supercharger system, premium aluminum-alloy cylinder heads and numerous details designed to ensure it makes its power as quietly and smoothly as possible. The supercharger, for example, has a unique, four-lobe rotor design that enhances quietness while also optimizing the performance parameters of the engine.
A pair of six-speed transmissions is offered in the CTS-V Coupe: a Tremec TR6060 six-speed manual with a dual-disc clutch and a Hydra-Matic 6L90 six-speed automatic with paddle-shift control. Performance Algorithm Shifting is part of the 6L90’s programming and provides a performance-oriented shift pattern during sustained high-performance driving. As with many Cadillac models, the driver needs only to slide the shifter into the manual “gate” to put the transmission into that more aggressive mode.
The paddle shift control requires no shift lever movement. Steering wheel thumb controls allow immediate and quick tap up/tap down gear selection.
The V-Series reaches elite levels of road-holding performance, but also maintains the poise of a luxury car in “regular” driving conditions. The technical enabler of that dual-mode driving character is Cadillac’s landmark Magnetic Ride Control. It is standard on the CTS-V Coupe and is the world’s fastest-reacting suspension technology. It uses shocks controlled by advanced magneto-rheological technology, rather than mechanical valves, to greatly accelerate response time and precision.
Electronic sensors at all four wheels literally “read the road” every millisecond, making constant adjustments to damping to create virtually instantaneous and extremely precise control of body motions. This is of particular benefit for a high-performance car because it helps keep the car very composed during hard cornering, acceleration, braking and other dynamic maneuvers.
The Magnetic Ride shocks also enable a broader range of damping control to optimize the ride and handling for all driving conditions. In the CTS-V Coupe, an extra measure of control is offered, with two selectable modes (Tour and Sport), enabling the driver to tailor the suspension for grand touring or more spirited performance driving.
Braking and tire systems
CTS-V includes sophisticated braking and tire systems, in partnership with two companies renowned for high-performance technology: Brembo and Michelin. Brembo brakes are at all four corners and include powerful, six-piston calipers in the front and four-piston calipers in the rear.
Slotted and vented rotors enable strong initial braking force while optimizing heat resistance and eliminating fade. The brake rotors from Brembo employ a “dual-cast” technology that combines cast iron and aluminum, resulting in excellent performance and weight reduction. CTS-V also includes an electric parking brake, enabling more legroom for the driver, key for high-performance driving.
Michelin partnered with Cadillac engineers to develop its acclaimed Pilot Sport PS2 summer tire for CTS-V and its exclusive 19-inch alloy wheels. The tires support high levels of grip in track conditions, while also affording good performance on the road.
Interior amenities
Recaro performance driving seats are optional in the CTS-V Coupe and provide excellent support for spirited driving. These 14-way adjustable performance seats include pneumatic bolster controls in the seat cushions and backrests.
The CTS-V Coupe also includes an exclusive new Saffron color option for the interior, providing a contrasting color accent carried on the seat inserts, as well as the stitching, which highlights the craftsmanship of the instrument panel, center console, door trim and seats.
The steering wheel, seat inserts and shifter are covered in microfiber, providing the luxurious character of suede without suede’s inherent drawbacks of difficult care and moisture sensitivity. These accents are standard, elegant to the touch and help support high-performance driving.
The car’s integrated center stack is trimmed in Obsidian black material that is also applied to the center console and door trim. Just like every CTS, the V-Series includes a hand-stitched instrument panel, door trim and center console. Leading-edge infotainment features extend to the V-Series. They include a 40-gigabyte hard drive, advanced navigation system with a deployable screen and Bose digital surround audio, as well as factory-installed Bluetooth phone integration, all standard features on the V-Series.
2023 GMC Canyon Elevation
Old 01-04-2010, 11:19 PM   #2
FenwickHockey65
More pictures...
Old 01-04-2010, 11:24 PM   #3
wbt
Drives: 2010 Challenger R/T;2011 Mustang GT
An amazing car for sure.
wbt is offline   Reply With Quote
Old 01-04-2010, 11:25 PM   #4
MEDISIN
Drives: 2011 CTS-V Sedan
Can't wait to see some performance figures. Is this the zeta platform as well?
MEDISIN is offline   Reply With Quote
Old 01-04-2010, 11:26 PM   #5
boxmonkeyracing
juggernaut
boxmonkeyracing's Avatar
Drives: VRSCF, 2011 SS vert
Send a message via AIM to boxmonkeyracing Send a message via Yahoo to boxmonkeyracing
can I please get one mommy. . ..
Originally Posted by fbodfather View Post
We do not want to use the Z28 moniker on a car that does not deserve this hallowed name.
boxmonkeyracing is offline   Reply With Quote
Old 01-04-2010, 11:26 PM   #6
FenwickHockey65
Nope. Sigma-II.
Old 01-04-2010, 11:29 PM   #7
Dave McFly
*new car smell*
Dave McFly's Avatar
Drives: 2007 Ford Mustang 'Natasha'
Send a message via ICQ to Dave McFly Send a message via AIM to Dave McFly Send a message via MSN to Dave McFly Send a message via Yahoo to Dave McFly Send a message via Skype™ to Dave McFly
Red face
from the press release:
I wish they could have done this on the Camaro, but it is still a sexy car, and I would so rock it regular OR V
"May the forces of evil become confused on the way to your house."
George Carlin
Dave McFly is offline   Reply With Quote
Old 01-04-2010, 11:49 PM   #8
meanmike
Drives: FIRST ON RACE DAY
The old design looked better. Still very nice though.
edit: I just realized this was a coupe and not the sedan.
meanmike is offline   Reply With Quote
Old 01-05-2010, 12:03 AM   #9
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2018 ZL1 1LE
Hot!!
I love how some of these cars today look like they shouldn't really be built...they look like show pieces. The Camaro and this new coupe are prime examples.
Old 01-05-2010, 12:07 AM   #10
meanmike
I dont like the rear. Ugly rearend's seem to be a trend with new car's now.
Old 01-05-2010, 12:19 AM   #11
The_Blur
Moderator
The_Blur's Avatar
Drives: 2018 Harley-Davidson Street Bob
Send a message via AIM to The_Blur
If I had the money, I would have trouble turning this down.
RDP Motorsport//GEN5DIY//Cultrag Performance//JPSS//Rodgets Chevrolet//
Operation Demon//Buy at Invoice//RACECARWEAR
RESPECT ALL CARS. LOVE YOUR OWN.
warn 145:159 ban
The_Blur is offline   Reply With Quote
Old 01-05-2010, 12:34 AM   #12
305pride
305pride's Avatar
Drives: 3.4l 1995 camaro
what an epic car. i predict gm will start getting a big head with this one. lol
just call me alex. they make anti-me PSA's cos im dope lmao
305pride is offline   Reply With Quote
Old 01-05-2010, 12:36 AM   #13
lil_chef
Drives: 2010 Mustang GT
looks like it will be even harder to see out of than the camaro...... ahh the prices we pay for driving beautiful cars.
lil_chef is offline   Reply With Quote
Old 01-05-2010, 01:18 AM   #14
Muscle Master
SS Lightning
Muscle Master's Avatar
Drives: An SRT8
Very nice, but I think I like the sedan better, personally I'm not a fan of the rearend
And with Both V coup and sedans ... it's one of those cars that just don't photograph well, you need to see them in person
Sex on wheels
The first rule of modding something that's not American is to not try to compete with modded V8 cars that are American. Really, they can run insane power with little investment. It's not even a fair fight.
Camaro 2SS RS, IBM, White Rally Stripes, custom fuel door: Status: going to the dealer: soon
Muscle Master is offline   Reply With Quote
Think about this and the Z28 5th gen 13F20 Camaro ZL1 Forum - ZL1 Specific Topics 41 09-04-2010 12:59 AM
GM Reveals 2011 Cadillac CTS Coupe! FenwickHockey65 General Automotive + Other Cars Discussion 47 05-20-2010 11:18 PM
Production Stats and information sherifdude USA - Southcentral 0 10-31-2009 03:07 PM
Answeres to questions I have stumbled on dieseldave24v 5th Gen Camaro SS LS LT General Discussions 13 02-23-2009 06:56 PM
CTC-V spied! (CTS Coupe) radz28 General Automotive + Other Cars Discussion 11 08-20-2008 12:22 PM
