Old 05-24-2021, 11:49 AM   #1
302SS
Drives: 2017 Camaro 2SS, Fifty
Wheel/Tire size help
I've been looking at getting the Niche Vice M226. I really want to run this wheel but I think the +35mm offset for the fronts are going to give me trouble.
These wheels come in 19x8.5, 19x9.5, 20x10.5, 20x9. All +35mm offsets.
Ideally I want to run:
M226 20x9 +35 fronts 285/30-20
and M226 20x9 +35 rears 305/30-20
Would this fit with any issues? I can't find a smaller offset for the front for this wheel... I would be okay with dropping wheel size to fit if anyone can help out.
Any help would be appreciated, thank you
302SS is offline   Reply With Quote
Old 05-24-2021, 12:01 PM   #2
Crushin_LT1
Crushin_LT1's Avatar
Drives: 2021 LT1 6spd
Those tires seem too wide for a 9in rim, especially the 305.
Current: 2021 LT1 Camaro, 6spd, Crush, Corsa NPP, GMPP CAI, Soler Performance Throttle controller
Previous: 1997 V6 Camaro, 5spd, Black
Crushin_LT1 is offline   Reply With Quote
Old 05-24-2021, 12:08 PM   #3
BrandanK
Drives: 2021 Camaro SS 1LE
As mentioned above, 9" wheel is going to be nowhere near a 305 wide tire.
265mm is going to be about right for a 9" wide wheel.
Ideally you are going to want an 11" wheel for 305s
BK
BrandanK is offline   Reply With Quote
Old 05-24-2021, 12:15 PM   #4
302SS
Would a 20x10.5 work with that tire size? (305/30-20?) I'd be okay with running a 285/30ZR20 in the rear as well if that's possible.
Only thing I'm set on is these wheels and running a Michelin Sport summer tire. I don't mind the sizes of the tire/wheel as long as they will fit.
I found one post of a camaro6 guy running these wheels with,
20x9 20x10.5 + 35 with 245 in the front and a 305 in the rear.
https://www.camaro6.com/forums/showthread.php?t=554096
What do you think would be the biggest tire size in the front with a 20x10.5 wheel that wouldn't hit the suspension / cause issues? If that's what could fit a 305 as well?
Thanks guys and sorry for all the questions. I've been on these forums for hours and reading tire/wheel setups :(
Old 05-24-2021, 12:41 PM   #5
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
20x10 and 20x11 or bust 20x9 is super narrow not worth it
Old 05-24-2021, 01:03 PM   #6
BrandanK
Here is chart that shows typical tire sizes for most wheel sizes.
https://www.tyresizecalculator.com/c...rim-size-chart
When you deviate from the normal Chevy spec'd sizes and offsets the information tends to get a little fuzzy. Some people have luck with a size, and others wont. The standard SS is 8.5"/9.5" with 245/275 tires front to rear. The SS 1LE is 10"/11" 285/305 tires front to rear.
I can't provide any feedback on offsets other than what GM has spec'd out already. Keep in mind that if you end up running a square setup (same front and rear wheel/tire), that you can rotate the tires for even wear, and will also extend the mileage warranty on most tires.
Krops, maybe we can try to help him instead of posting one-line comments.
BK
Old 05-24-2021, 01:04 PM   #7
Envious_Ivy1LE
Envious_Ivy1LE's Avatar
Drives: Krypton Green V6 1LE
I just picked up a set of niche m259, 20x9 +35 front and 20x10.5 +35 rear.
I'm going to be putting my rears on the front (275/35) and ordering new rears (305/35) assuming I can confirm 305/35 won't rub. bear in mind I'm in an LT so the fronts were .5 wider and 1.0 wider in the rear for me.
If you're just going for the look, it should be fine.. you need a spacer up front since it's going to be sunken vs stock, especially for an SS. If you're going for performance I'd probably look at a different brand with wider wheels and better offsets
I'm using this to compare fitments
https://www.willtheyfit.com/index.ph...h=9&offset2=35
Envious_Ivy1LE is offline   Reply With Quote
Old 05-24-2021, 01:06 PM   #8
kropscamaro16
BK
lol that is my helping if you are going to aftermarket there is no point is going 20x9 that doesnt make sense
20x10 20x11 is oem 1le / zl1 sizes and there is a search function on the website that has plenty of info on this not the first wheel/tire size help post...
Old 05-25-2021, 01:52 AM   #9
302SS
BK
I appreciate it! I actually didn't know that the stock wheels were 8.5/9.5, just knew the offsets for them. That helps. So I definitely should stick with the 10.5 option for both rear/front? I do want to stay as close as stock as possible, to avoid rubbing and issues. I like the look/functionality of a square setup, but from reading everyone needed spacers. If I ran the 10.5 with 285's square setup, for example, wouldn't I need a 5mm spacer in the front?
https://www.willtheyfit.com/index.ph...0-5&offset2=35
I think that's pretty close to what I was looking for, for tire sizes. So I could probably do similar to what you're doing just with that wheel.
Are you going to rub with a 275 on a 20x9 with +35mm offset without a spacer? If you don't, I think that's what I want to go with to be honest.
For the performance aspect, my current tires are stock wheels with 245 in the front and a 275 in the rear, so this will be an upgrade and a much wider tire than what I have. I want to obviously keep the handling ability, and get better traction. I won't see a track probably, but spirited driving.
I searched for hours trying to understand different setups. It's my first time so I just didn't want to shell out thousands and mess it up, that's all.
I appreciate all the help guys, thank you
Old 05-25-2021, 10:12 AM   #10
Envious_Ivy1LE
I eyeballed MRR 1LE replicas for my fitment (which are SS 1LE specs). they suggest a 285/30/20 on 20x10 +23. it's 17.1mm closer to the strut and 21.1mm more poke. I didn't want to go over these numbers so a 10.5 in the front is too wide. you'd need a 18mm spacer to get to that 17.1 mm figure which would give you 33 mm more poke. you can research and see if anyone else is doing anything like that but I don't know how to measure clearances lol I just know how to compare numbers.
As far as rubbing I should be fine. I'm doing extended studs and a 20mm spacer in the front. I'll be away from the strut vs stock and 10.5 mm taller tire. I'm pretty sure I'll have room. I Will have to relocate the harness in the rear apparently. Also I just realized V6 1LE and stock 1SS have the same wheel specs
Old 05-26-2021, 11:57 AM   #11
302SS
Awesome man, hope it works for you.
I actually just ordered MRR FS01 wheels 20x10 +23mm front and 20x11 +43mm rear. Thanks for all the help guys.
Old 05-26-2021, 12:35 PM   #12
BrandanK
Please post photos when you get the FS01's mounted up. I'd love to see how they look.
Brandan
Old 06-11-2021, 12:43 PM   #13
302SS
Brandan
Definitely! I've had the wheels for a week, they were supposed to take a month but came extremely fast...I have been fighting to try and find a set of tires in stock ><. I really want Michelin Super Sports or Michelin Sport 4S. Seems like Michelin aren't making any until July... looks like amazon has 275/30r20 and a 305/30r20 in stock, might go with that setup instead of a 285 in the front because I can't find them in stock to save my life. Would a 275 vs a 285 in the front even be that noticeable of a difference? I don't know.
Might settle with a Eagle F1 or a Continental Extreme Contact to get a 285 front -> 305 rear setup, which tire rack has in stock.
Old 06-11-2021, 12:49 PM   #14
DaveC113
DaveC113's Avatar
Drives: 2018 Camaro 1SS 1LE
I'd prolly just go Conti, they are pretty good and much less $ in 20"sizes.
