![]() Drives: 2021 1ss a10 Join Date: Aug 2020
2021 1SS A10 with npp
First run is in track mode, traction on, stabilitrac on. 12.64
Second run about an hour later sport mode, traction on, stabilitrac on, 12.37. Sorry can’t figure out how to rotate pics.
2021 1SS A10 NPP
![]() Drives: 2018 Camaro Join Date: Apr 2021
Nice runs man!
![]() ![]() ![]() ![]() ![]() Drives: 2017 Camaro 2SS A8 Join Date: May 2019
Keep at it! Did you lower air pressure?
I should have added more… car is 100% stock including the run flats. Tire pressure was 37 all four corners. Small burnout on the 12.64 pass. No burnout on 12.37 pass. Both passes I left with left foot on brake and mashed the gas. No converter flash with holding the brake on a little after mashing the gas. No spin on either run and did not notice traction light.
Next time will try with nannies off and flash the converter a little.
2021 1SS A10 NPP
Thanks for the compliments. I was super pumped at how it ran on these baseline runs.
2021 1SS A10 NPP
![]() Drives: 2021 Camaro LT1 RS Join Date: Jul 2021
The 6.2 Camaro reminds me so much of the ‘62-‘64 “Max Wedge” 413 and 426 MoPars which dead stock with slicks and TorqFlite ran high 11’s to mid 12’s with the Lakes Pipes open. Absolute beasts!
