Old 05-12-2021, 06:22 PM   #1
1wraith76
Drives: None
Notchy shifter
I bought a used 2018 ZLE. The shifter feels a bit notchy. I can feel the synchros when I shift. Is this normal or should I have it looked at?
1wraith76 is offline   Reply With Quote
Old 05-12-2021, 06:24 PM   #2
LT4Greg
LT4Greg's Avatar
Drives: 2017 Camaro ZL1 Coupe
Yes my ZL1 shifter is notchy too!
Old 05-12-2021, 06:32 PM   #3
1wraith76
Drives: None
Thanks. Every car is so different I just wasnt sure. Good to know I dont need to replace any synchros.
Old 05-12-2021, 10:00 PM   #4
SFV1LE
Drives: 2018 Hyper Blue ZL1 1LE
Are you saying it's always notchy and you always feel synchros, or only when it's cold shifting into 1st, 2nd or reverse?
I'm not sure what you mean by "feel the synchros". If you actually feel/hear it grind into gear then no I never feel that except the 2-3 times over last 2-1/2 yrs when I didn't clutch/shift right and got a buzz from synchros.
There is never any synchro buzz and mine is only a bit notchy when cold, after 5-10 minutes it feels very smooth and firm.
SFV1LE is offline   Reply With Quote
Old 05-12-2021, 10:21 PM   #5
nighttowl
Sarcasm loading --------
nighttowl's Avatar
Drives: 2018 ZL1 1LE
mine is notchy if i dont drive it for a while. after driving it for a day it works itself out.
if it doesnt go away i would check out the clutch to make sure its completely disengaging.
ive been driving with a tr6060 for nearly a decade now, i may be desensitized to it.
2018 MBM ZL1 1LE - 652 rwhp, 588 rwtq SAE
2014 CRT ZL1 574 rwhp, 537 rwtq - SOLD
2010 IBM SS Camaro VVT L99 w/ TR6060 swap, 489 rwhp, 444 rwtq - SOLD
nighttowl is offline   Reply With Quote
Old 05-13-2021, 05:07 AM   #6
1wraith76
Drives: None
I will just have it checked out when I bring it in for the power steering. Just in case. Thanks everyone.
Old 05-13-2021, 08:07 AM   #7
LT4Greg
LT4Greg's Avatar
I really don’t think you have any issues with your transmission but get it checked anyway to ease your mind! Those transmissions are tough and shift differently than other transmissions!
Old 05-13-2021, 09:21 AM   #8
avalonandl
avalonandl's Avatar
Drives: 2019 ZL-1
My 17 2ss was notchy. Its the tremec characteristics.
Old 05-13-2021, 01:07 PM   #9
Sickspeedkuwait
Sickspeedkuwait's Avatar
Drives: '17 ZL1 M6
Notchy 1-2 when cold.. Much smoother when warmed up
'17 ZL1 M6
8xxwhp Magnuson 2650
Sickspeedkuwait is offline   Reply With Quote
Old 05-13-2021, 04:55 PM   #10
Warrior102
USCG Retired (MKC)
Warrior102's Avatar
Drives: 2018 2SS 1LE Black
The OEM fluid is crunchy at best and down right useless when the temps drop, I've tried Mobil 1 SYN ATF (recommended by Tremec), Redline D4 and Royal Purple Syncromax over the last 30K and the RP is by far the smoothest shifting fluid overall (IMHO) regardless of temperature.
Warrior102 is online now   Reply With Quote
Old 05-13-2021, 06:22 PM   #11
semif18
Drives: 2018 ZL1 1LE White
I have a 2018 ZLE. Shifter has always been smooth and seamless regardless of temp.
semif18 is offline   Reply With Quote
