![]() Drives: 2018 2SS 1LE 416 NA Join Date: Feb 2021
Cons of running E85 all the time?
I have a FBO, cammed 18 1LE and about to get a flex fuel tune. Here in Charleston we have plenty of places to get good E.
What are the cons of running Straight E85 all the time?? |
![]() ![]() ![]() Drives: 2020 LT1 M6 Join Date: Jan 2016
30% less fuel economy and not recommend to be left in the tank if the car is going into storage.
![]() Drives: 2018 Chevrolet Camaro 2SS 1LE 6M Join Date: Jul 2019
Tire wear. With all of that extra power you tend to spin the rear wheels a bit more.
Bolt-ons.
There is no downside in my opinion and have been running it on my C7 for about a year. Once you install the flex fuel sensor your tuner will set up another table that adds timing so you'll def feel the additional power it makes. I agree on the storage and what I did I ran mine all the way to November and ran the tank down to about an 1/8 tank or less then added 93 octane and ran it all winter when the days here in Missouri were nice enough to get it out. My C7 picked up almost 1/2 second and 4 mph just by changing over to E85 (E70) and tuning. Can't beat that with a stick, then I added long tubes and xpipe, then retuned again and have went as quick as 11.06@125 w/1.58 60ft. I do of course run a drag radial at the track. My best time on 93 was 12.06@116 w/1.80 60ft
I noticed a post that said its 30% less on fuel economy. Mine will get about 29-30 mpg on 93 octane and 23-24 mpg on E65 to E70 which is what I can usually get in this area. The higher the E content the mileage goes down. So mines not in the 30% range, maybe because of the arrow of the C7 compared to the Camaro which is not a slick going thru the air as the Corvette.
The fuel mileage loss is off set by the lower cost which still makes E cheaper to run.
Far as storing the car with E in the tank... By the time you go to store the car, most areas have switched to winter blend E which is around 65%. I haven't had any issues leaving Winter blend E in the tank while the car is stored inside. Now if we were talking about C85 or X98 from a drum, then yea you might want to dilute that a bit while storing the car.
#7 |
Joe your winter blend is what I get in the summer here in Missouri. When I first put in E this spring it was under E60.
#8 |
![]() Drives: 2018 1SS 1LE Join Date: Dec 2012
Been running e85 for 3 years. No problems to speak of.
#9 |
![]() Drives: 2017 Camaro 2SS Join Date: Mar 2019
I read that the MPG reduction was 15%-25% depending on compression ratio and other factors. Just got back from an E85 run today, have to go about 25 miles out to get it, worth the drive, with a couple 5 gallon tanks in the trunk for good measure. Fun moment, some old man yelled at me for hoarding fuel because of the pipeline thing...
Gary
2017 2SS A8 White, Bolt-Ons, Prayed Upon |
#10 |
Drives: Nickey Super Camaro Join Date: Nov 2008
You should compare e85 to race fuel not regular fuel, but dollar for dollar e85 is still a better "fuel" deal in our market. We run it in all of our late model cars and trucks which are properly set up to do so.
A major issue will be that you face muscles will hurt from smiling so much do to the overall increase in performance. I also happen to be able to tolerate the smell better than 87-93 and it doesn't tear me up as bad either. BTW.....been running it for two decades. |
#11 |
Thanks for all the Info. Yes it is a Manual car and its my daily driver so no storing. I dont mind the decrease in fuel mileage because it cost less than 93.
Also getting a flex fuel tune with Vengeance Racing, which has already tuned my car for 93. Thanks guys. |
#12 |
![]() ![]() ![]() Drives: 2016 2SS BLK A8 Vert Join Date: Dec 2017
For a little piece of mind, you could also run some Schaeffer's SoyUltra Additive with the e85... I just started using it this past weekend
![]() https://www.schaefferoil.com/soyutlra.html This is the sales rep I have been going through for my oil and products:
#13 | |
#14 | |
