Old 05-10-2021, 10:26 PM   #1
nighttowl
Sarcasm loading --------
nighttowl's Avatar
Drives: 2018 ZL1 1LE
Possible oil pressure issue
My car odd oil pressure lately.
when it was new it had about 40 psi at idle warm. after a few thousand miles it went down a little to about 30 psi at warm idle, and at higher RPM it seemed to never go over 45ish on the display. I took it to the track recently, and changed the oil to the thicker oil. I rarely drive the car, and the oil is still in it. I drove it today and the oil pressure at a higher rpm is more than before; to what I would say is normal (50+), but its lower at hot idle than ive ever seen it - around 20-25 psi. The car has 14k miles on it. I think its low, compared to what it was new.
what is normal oil pressure on these engines?
do you think it may have an issue?
2018 MBM ZL1 1LE - 652 rwhp, 588 rwtq SAE
2014 CRT ZL1 574 rwhp, 537 rwtq - SOLD
2010 IBM SS Camaro VVT L99 w/ TR6060 swap, 489 rwhp, 444 rwtq - SOLD
nighttowl is offline   Reply With Quote
Old 05-10-2021, 11:14 PM   #2
SSallday
SSallday's Avatar
Drives: ‘18 ZL1 / ‘22 ZLE
Sounds like your oil pump is starting to fail. The pressure should be around 28-30psi at hot idle. This thread basically verifies that. https://www.camaro6.com/forums/showthread.php?t=532479
There's a chance it could ruin your engine if the pump fails while you are driving. I would bring it to the dealer and explain the situation. What's the build date on your car?
SSallday is offline   Reply With Quote
Old 05-10-2021, 11:36 PM   #3
nighttowl
nighttowl's Avatar
not sure where to find it.
I bought it new in august 2017.
Old 05-11-2021, 12:11 AM   #4
2SS Capt
2020 Shadow Gray 2SS
2SS Capt's Avatar
You should still be under the powertrain warranty, take it to a dealer and get it checked, the LT4 did have an oil pump failure issue...
Old 05-11-2021, 12:18 AM   #5
SSallday
SSallday's Avatar
Most of the failures occurred in the 2017s. There's a gray sticker on the driver side door jamb with the build date. It's only a matter of time before your pump fails completely, which could be catastrophic.
Old 05-11-2021, 12:26 AM   #6
nighttowl
nighttowl's Avatar
Thanks fo ryour thoughts on this.
I'll take it to the dealership to be looked at.
Old 05-11-2021, 07:40 AM   #7
LT4Greg
LT4Greg's Avatar
Drives: 2017 Camaro ZL1 Coupe
Don’t know if the dealer will do anything for you except make a notation with your vin since you haven’t had a failure yet! Good luck and I’m keeping a watch on my 2017 every time I drive it now wondering if it will fail too. Mine has around 19,000 miles so far.
Old 05-11-2021, 08:35 AM   #8
Trak-Toy
Trak-Toy's Avatar
Drives: 2023 SS 1LE
That’s the tell tale sign of impeding ‘total’ pump failure I’m told... once the hot idle shows 20 PSI, the cracks have occurred and the next step is total failure and potentially catastrophic engine damage. I would definitely not be driving or starting it anymore. Flat bed straight to the dealership. You may have gotten ‘lucky’ and caught it before it totally ruptures and sends debris into your oiling system. Most guys don’t even get that or don’t notice that low pressure until it’s too late.
Here’s my 18 ZLE at hot idle. Always seems to stay right at this 30 PSI mark. This is Mobil 1 Extended Performance 5W30 oil.
Trak-Toy is offline   Reply With Quote
Old 05-11-2021, 08:58 AM   #9
avalonandl
avalonandl's Avatar
Drives: 2019 ZL-1
Which weight oil is in it and did you track with that oil. I think your pump is OK but I would change oil IMMEDIATELY.
Old 05-11-2021, 12:23 PM   #10
LT4Greg
LT4Greg's Avatar
My 2017 at hot idle is sometimes between 20 and 30 but not always.
Old 05-11-2021, 04:50 PM   #11
Trak-Toy
Trak-Toy's Avatar
Drives: 2023 SS 1LE
I am just going off what I was told by people who have had the oil pump failure. I won’t say it’s the definitive symptom. I’m not sure if there is one. I’ve read also where the oil pump just goes all at once, with no symptoms of pending failure. Who knows for sure? I will say that my 2018 ZLE holds steady at 29/30 psi when hot. And that’s with oil temps at 260*+ from ‘spirited’ driving. Is this normal? I don’t really know. With these pumps known to fail, if I see it drop to 20 psi or below, it’s going straight to the dealership to open a case file with GM noting the issue while it’s still under warranty.
Old 05-11-2021, 07:25 PM   #12
LT4Greg
LT4Greg's Avatar
Yeah I know what you are saying. It’s a shame we have to keep our eyes on the oil pressure gauge while driving! I surely don’t have to do that driving around in my 2005 Silverado truck with a 4.8 liter V8 LS variant engine that has over 96,000 miles.
Old 05-11-2021, 07:31 PM   #13
LT4Greg
LT4Greg's Avatar
And I use 5w30 Valvoline Synthetic in the truck and 5w30 Lucas Synthetic in the Camaro. Last oil change I did I used Lucas in the ZL1 just to try it and might go back to Valvoline though next oil change.
Old 05-12-2021, 07:08 AM   #14
ZLE dude
Drives: '18 ZL1 1LE
Same here. I use a Banks Data Monster and I have it setup to alarm if my oil pressure ever goes below 27psi. I'm at nearly 26K miles now and it has always hot idled with 28-30 psi. That low oil pressure alarm is the first thing I setup because if I ever see it lit up I'll know something has changed immediately.
2018 ZL1 1LE - Summit White, PDR, Rotofab CAI, 95mm TB, CSP 2" catless LT's, JMS Voltage Booster, AEM X-series WB, DSX flex fuel sensor, Banks Data Monster, Tuned by Ted Jannetty, 5% Tint, Blackvue DR900S-2CH, Diode Dynamics lighting, IGL Kenzo ceramic coating
ZLE dude is offline   Reply With Quote
