Old 05-09-2021, 05:07 PM   #1
seethruya
Drives: 2021 Camaro LT1 Conv
Took the LT1 to get a dyno.
Not to bad. Flat curve, almost 410HP and 435ft/lb stock, only have an exhaust.
https://www.instagram.com/p/COqhozYj...d=989agtulhknc
seethruya is offline   Reply With Quote
Old 05-09-2021, 05:25 PM   #2
VR Baron
SoCal Camaro5 Race Team
Drives: 2021 Shadow Grey Camaro 2SS 1LE
Nice! Auto or manual? Also std correction is about 3-4% higher then sae correction. Just a fyi
VR Baron is offline   Reply With Quote
Old 05-09-2021, 08:44 PM   #3
BruceWayne1LE
BruceWayne1LE's Avatar
Drives: 2018 Camaro SS 1LE M6
Am the only one that looks for the 5252 rule?
Camaro 2SS 1LE, MBRP Catback, Mishimoto Catch Can, Rotofab dry, TSP1 7/8” headers,DSX FF, Pray ported MSD, 95mm TB
492WHP 473WTQ
BruceWayne1LE is offline   Reply With Quote
Old 05-09-2021, 08:49 PM   #4
s346k
s346k's Avatar
Drives: like an old lady
not at all. that was the first thing i noticed when i saw the pull ended at "5800" rpm. i'm guessing the graph needs to slide over.
Old 05-09-2021, 08:53 PM   #5
BruceWayne1LE
I would assume it’s because it’s uncorrected. But I’ve always assumed it was a result of a dyno that’s with A. Not properly calibrated or B. It’s been tampered with.
492WHP 473WTQ
Old 05-09-2021, 08:59 PM   #6
gtfoxy
Drives: '21 Wild Cherry ZL1
Yeah, something’s funky.
Mathematically impossible.
Old 05-10-2021, 06:25 AM   #7
auto_god
auto_god's Avatar
Drives: 2021 Camaro 2SS 1LE
My guess would be if the torque and hp were scaled the same on the graph, it would cross over at 5252.
auto_god is offline   Reply With Quote
Old 05-10-2021, 09:16 AM   #8
Doc Oc
Drives: 2017 Camaro 2SS
STD isn't uncorrected fyi, it's just a different factor than SAE.
The weird thing is it picked up 20 hp/tq between first run and last. Were these done back to back? No tuning?
2017 2SS A8 TSP LT's, ported msd/95 mm, e85
Doc Oc is offline   Reply With Quote
Old 05-10-2021, 11:53 AM   #9
seethruya
The first two pulls were done back to back when I arrived. The last pull (409) was done after letting the vehicle cool down for 30 minutes. 30-45 minute drive to the location. It was mid 90s, high humidity yesterday in central Texas.
Old 05-10-2021, 11:56 AM   #10
seethruya
It’s a manual.
