Old 05-09-2021, 08:53 AM   #1
Michael-k
Michael-k's Avatar
Drives: '21 Camaro
How to add a circuit?
In order to realize my electronic happiness, I am working on installing some stuff in my Camaro. These units will all be in/near the dashboard, and draw 6 A maximum.
So, I'll need to add a circuit. Has anyone done this?
Should I add it to the front or rear fusebox? (Both have empty fuse slots.) Are the fuseboxes fully wired, or will I have to do that too?
I found a chart that gives wire gauge for a 12V circuit (for a given current and length).
I think that the only 'issue' would be getting the terminal to use in the connector on the fusebox. Anyone know the spec?
DD: 2014 Chevrolet Equinox LT1 -- Silver ice, LFX, AWD, moonroof
2021 Chevrolet Camaro 3LT -- Riverside blue, LGX, M6, NPP, moonroof -- Insta @bluehoney3lt
sold: 2000 Mercury Cougar -- V6, citrus gold, 5-speed, sunroof
Michael-k is offline   Reply With Quote
Old 05-09-2021, 12:19 PM   #2
I have the 2018 service manual and found the pages discussing the underhood fuse block (X50A), complete with ratings and descriptions. If you think these may be helpful, I can post them up, but with the caveat that your 2021 fuse block will definitely not be a 100% match.
Old 05-09-2021, 01:08 PM   #3
The Maverick
Somewhere in the Kalahari
The Maverick's Avatar
This may work for you -- the Gen5DIY guys provided me with a wiring harness using the fuse tap connector pictured below. I am swapping a '16-18 front bumper onto a '19+ RS which does not have DRL's, so this adds a 15A fused wiring harness to connect the DRL's to a circuit that comes on with the ignition. The tap replaces the appropriate fuse in the fuse box, and the original fuse is then plugged into the open slot on the tap.
Old 05-09-2021, 04:00 PM   #4
Michael-k
Michael-k's Avatar
Drives: '21 Camaro
Ok, that's an option.
Actually, I know about fusetaps -- but I didn't even think about doing that.
I don't really like it (non-elegant), and what if a service tech has to work in the fusebox? Would he know what it is?
I don't mind putting in a bit of effort to make it 'OEM'.
Thank you for the suggestion. Maybe I'll use it.
Old 05-09-2021, 04:03 PM   #5
Michael-k
Michael-k's Avatar
Drives: '21 Camaro
I'd like to check it out -- maybe it'll help.
Does it have the trunk fusebox?
Thank you!
Old 05-09-2021, 04:48 PM   #6
Thank you!
Sent you a PM.
Old 12-30-2024, 12:30 AM   #7
2018 Blue 1LE
2018 Blue 1LE's Avatar
Drives: 2018 Hyper Blue Metallic 2SS 1LE 6M
Did you ever get this figured out?
I, too, would like to add a factory looking fuse to the fuse box instead of other options.
2018 Blue 1LE is offline   Reply With Quote
