Old 05-07-2021, 09:52 PM   #1
MyNightfallZL1
MyNightfallZL1's Avatar
Drives: 2018 Camaro ZL1
ZL1 supercharger lid
Does anyone have any suggestions on how to clean the supercharger lid for the 2018 ZL1 Camaro? The car was a Florida vehicle and it looks like it has water spots on the lid.
MyNightfallZL1 is offline   Reply With Quote
Old 05-07-2021, 10:08 PM   #2
Chippy
BanHamWatch
Chippy's Avatar
Drives: 21 ZL1 1LE
You could try a 50/50 mix of water and vinegar let sit for a couple minutes and rinse, if that is not strong enough there are water spot removal products that are harsher. I always start simple and delicate then move up to stronger products.
2021 ZL1 1LE
Auto
Chippy is offline   Reply With Quote
Old 05-07-2021, 10:22 PM   #3
MyNightfallZL1
Thank you.
Old 05-08-2021, 12:04 AM   #4
LT4Greg
LT4Greg's Avatar
Drives: 2017 Camaro ZL1 Coupe
Hey Nightfall, add some antifreeze to your top reservoir. It’s low!
Old 05-08-2021, 12:17 AM   #5
Camaro1973
Camaro1973's Avatar
Drives: 2019 ZL1
Maybe the reason for it being low is those "water spots" Maybe it isnt water
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90
Old 09-22-2023, 09:39 PM   #6
Booher
Booher's Avatar
Drives: 2019 zl1 6 speed
Did you ever resolve this issue? I bought a used zl1 from Florida and have the same issue.
Old 09-23-2023, 08:54 AM   #7
Jus Cruisin
Old Gearhead
Jus Cruisin's Avatar
Drives: 2023 GMC Sierra Denali Ultimate
He's long gone. Last seen a year and a half ago.
2023 Camaro ZL1 convertible - black - SOLD
2025 GMC Sierra Denali Ultimate - black - 3.0l diesel
1937 Ford Slantback
Jus Cruisin is offline   Reply With Quote
Old 09-23-2023, 09:43 AM   #8
Booher
Booher's Avatar
Doh, haha ok thanks! I want to paint it, but don't know how to tape everything else off, so I'll try that vinegar idea.
Old 01-17-2024, 03:44 PM   #9
Bjcamaro
Drives: 2023 Camaro ZL1
Where you able to get the water spots off? I have the same problem and the vinegar did not work for me.
Thanks
Bjcamaro is offline   Reply With Quote
Old 01-17-2024, 03:54 PM   #10
CalgaryZL1
CalgaryZL1's Avatar
Drives: 2020 Chevy Camaro ZL1
Try neverdull, It is awesome for aluminum. Read the directions and you will be good to go.
Old 01-18-2024, 12:27 PM   #11
Booher
Booher's Avatar
Heck yah, I'll try that, thankyou for the suggestion.
Old 01-19-2024, 07:17 AM   #12
hawk02
Coupe Newbie
hawk02's Avatar
A more expensive option but one that will require significantly less work to maintain over the long run is to have the lid custom painted.
I bought a custom-painted lid from RPI Designs back in 2018. I just wipe it down after each wash. It looks just as good today as it did in 2018 when I installed it.
Old 01-19-2024, 07:49 AM   #13
DZ28
DZ28's Avatar
Drives: 2023 ZL1 M6 Riverside Blue
Or chuck it completely >> https://www.mechanicalpower.net/shop...ercharger-lid/
The powdercoat I chose is a wrinkle finish and zero spotting.
** Sadly SOLD ** IBM 2SSRS Camaro M6... 2023 Riverside Blue ZL1 M6, 1 of 75
DZ28 is offline   Reply With Quote
