Old 05-07-2021, 04:28 PM   #1
ibfootin
Drives: Camaro ZL1 1LE
Speed limiter at 200MPH
Is there a speed limiter on a 2018 ZL1 1LE. My HP tuner shows i drop timing at 200 mph----- (18degs to -10degs)
ibfootin is offline   Reply With Quote
Old 05-07-2021, 04:38 PM   #2
I have a standard ZL1 tune that sets the limiter to 206 mph. Not sure about the 1LE.
Old 05-07-2021, 05:33 PM   #3
crosive
Drives: 18 zl1
I don't recall anything but the verts having a hard limiter. Also, since you've had your 1le faster than the drag limited top speed, I can imagine it's gonna start getting pretty tough once heat starts setting in. especially after a 200mph pull, that doesn't come quick.
crosive is offline   Reply With Quote
Old 05-07-2021, 08:55 PM   #4
ModernCamaroZ28Fan
LT1_Radenso
ModernCamaroZ28Fan's Avatar
Drives: a 2 spd water bottle
ZLE's top speed is limited around 190 MPH opposed to the ZL1's 200.
ModernCamaroZ28Fan is offline   Reply With Quote
Old 05-07-2021, 09:05 PM   #5
crosive
Drives: 18 zl1
Stock for stock, I've not heard of anyone doing much past 180 in a zle.
But I haven't much looked
Old 05-07-2021, 09:51 PM   #6
Heat Magnet
Drives: 2021 Chevrolet Camaro 2SS
I think the ZL1 1LE is drag limited to under 200 mph
Cars I own/drive:
  1. 2007 Chevrolet Cobalt LT Sedan
    Ultra Silver Metallic, gold painted wheel covers, 4T45 transmission
  2. 2021 Chevrolet Camaro 2SS Coupe
    Black, Redline Edition, 1LE Suspension Package, 10L80 transmission, NPP, Body color high wing spoiler, Ground effects kit, 48-state legal Brembo brakes
Heat Magnet is offline   Reply With Quote
Old 05-08-2021, 08:06 AM   #7
redcoats1976
are you the one that passed me on I-4 yesterday?
redcoats1976 is offline   Reply With Quote
Old 05-08-2021, 09:14 AM   #8
Timbo-1LE
Timbo-1LE's Avatar
Drives: 2017 SS 1LE
I did 174 in SS 1LE at Kennedy Space Center (verified at 172.xx). A year later a ZLE did I think 8-10 over that.
My video is somewhere buried in here... My car hit a aero wall about 160, run was also with road course alignment which did not help. In short, your gonna need lot of power to go over 200...
Timbo-1LE is offline   Reply With Quote
Old 05-08-2021, 11:20 AM   #9
wnta1ss
Drives: 2017 Camaro 1SS
Yes there is, limiter at 206 and resume at 204. That is a file from a 2018 ZL1/LE. Those are the same settings as a 2017 ZL1 file that I've checked. Screenshot will be below the text.
Agree with the others that drag is very high on this model. You must have a lot of extra power to go that fast. The test that Timbo-1LE was talking about was a 2.7 mile run where the ZLE reached 178 mph. Watching that video, it's apparent to me that drag is very high on this model, because of the way a 650 hp car is struggling so much at higher speed. My perspective on that opinion is from making a bunch of runs at 170+ in just 1.0 mile with my Camaro SS partial-bolt-on car, which has a good bit less hp than a ZL1.
Old 05-08-2021, 11:58 AM   #10
LT4Greg
LT4Greg's Avatar
Drives: 2017 Camaro ZL1 Coupe
Do you plan on going over 200 mph in your ZLE? You would probably need a full roll cage and racing belts/harnesses.
Old 05-09-2021, 07:34 AM   #11
He11bent
He11bent's Avatar
Drives: 2019 2SS Convertible Camaro
Tires will a limiting factor. They have to be designed to go 200 mph and dont last long at that speed. You should research this. There are few threads on here about this.
\(^^^)/ <--A Smile From He11
Escort 360 MAXX w/DIYGen5 hardwire Harness
K&N AirCharger Cold Air Intake
Sound Tube Delete
He11bent is offline   Reply With Quote
Old 05-09-2021, 08:01 AM   #12
True, but at 200 mph he'll run out of gas sooner than (Y rated) tires
Old 05-09-2021, 08:47 AM   #13
ibfootin
No it wasn't me. I am in Houston
Old 05-09-2021, 08:50 AM   #14
ibfootin
I have all that and my car drops timing just after 200 mph and i am wondering what i can do so it doesn't drop timing
