![]() Drives: 2019 camaro 2ss Join Date: Feb 2020
Adding big gulp and TB to boosted SS
I currently have a whipple/catless longtubes, an axle back and lt4 fuel system and the car is only making 557whp 575 tq, what kind of gains do you guys think I’d make with a rotofab big gulp and a bigger TB, I figure it’ll really let the car breathe compared to the stock SS intake and get good results. The only reason I’m debating on doing it is because of the cost of having it retuned.. I want it to be worth it. Would love to hear what you guys are making with similar setups
2.9 Whipple, CSP longtubes, borla atak, lt4 fueling, dsx aux pump, big gulp, nw 103mm, zl1 rep wheels, Toyo r888r
![]() Drives: 2015 C7 Z06 M7 Join Date: Dec 2012
Here were my findings with a 103mm and the standard Rototfab.
https://www.camaro6.com/forums/showthread.php?t=487611 I doubt the big gulp will provide additional benefit at a power level <750 RWHP. (but that's what I would get anyway for "future proofing")
I had to add 2-3% of fuel up top to maintain the same AFR after I installed the Big Gulp. That tells me the engine is making more power. I am guessing 15-25whp coming from a stock airbox on your setup...bigger gains to be had with more aggressive setups.
![]() Drives: 2016 Chevy Camaro 2SS Join Date: Aug 2012
Honestly big gulp wouldnt be beneficial until you get in the 700 range
![]() Drives: 2017 Camaro 1SS M6 (SOLD) Join Date: Oct 2016
Consider this (more info below): Long tube (was already catless which netted me +23/+4), NW 103 TB and big gulp = +34rwhp & +23 tq. Alot of $ for minimal gains.
------------------- Spent some time the other day and figured out the progression of my build, see below. I know this will help others out decide on mods and whats worth it and what is NOT for the gains. 2017 Camaro SS M6 (rwhp/rwtq) OS = Over Stock OP = Over Previous Setup Complete Street Performance / Dynojet Stock 417/428 Stock Tuned 429/440 +12/12 OS Whipple 3.50 pulley, LT4 HPFP, LT4 Injectors, RotoFab Dry, Stock exhaust w/ Cats 597/591 +180/163 OS +168/151 OP (stock tuned) Previous Plus: NEP Cat Delete Pipes (primary & Secondary) 620/595 +203/167 OS +23/4 OP Previous Plus: Borla Atak, Borla Resonator, Kooks 2” LTH, NW 103 TB, RotoFab Big Gulp, Granatelli Plug Wires, Gforce AL DS, DSS Axles 654/618 +237/190 OS +34/23 OP ***This step was very costly and yield little results for the $ spent*** Retuned by EFX/Mustang Dyno 688/632 I went and got it retuned by EFX after talking to them about the bog issue and the torque management. Also there was a rough/weird spot down low i didnt like. Both were taken care of. Perhaps I could next look back and try and match up best 1/4 mile on each setup.
Stock: 416hp/427tq, 12.21 @ 116.80 Modified 02/2019: Whipple SC w/ 3.500 pulley, LT4 fueling, NW 103 TB, Roto-Fab Big Gulp, Kooks 2" jet coated, full Borla ATAK exhaust, DSS axles, Gforce driveshaft. Tuned by EFX Tuning 688hp/632tq Best 1/4 to date: 10.705 @ 131.92 |
Actually I was just talking to Mike that owns Roto-Fab a few days ago and that discussion came up. You are better off with the 4" unless you are at least 700 rwhp. That's from his mouth and he should know since he designed both of them. You just aren't moving enough air at your boost level and HP level to make it worth the extra money. I made well over 700 rwhp with my 2300 Maggie and a 4" Roto-Fab. Now that said results may very.
#7 | |
#8 | |
#9 |
I would recommend it but you may be able to get by without it. Contact your tuner for his opinion. You are going to move more air with the Roto-Fab so may need a little tweaking.
#10 |
Petro-sexual
I experienced something similar, too. No change except the BG. That was moving from the standard RF to BG, just to be clear.
#11 | |
Does that mean you can't make power through a 4"...nope. You can make power through stock intake, tb, and exhaust...All you do is add boost to over come restrictions which reduces efficiency, creates more heat, and puts more strain on parts. I like the idea of power through efficiency.
#12 |
![]() ![]() Drives: 2018 Camaro SS 1LE Join Date: Jul 2018
Mr Jannetty mentioned my OEMish LT1/4 would gain very little if any between the two. But what would happen is the resolution of the airflow signal would be reduced for the MAF possibly impacting driveability. This outweighed the benefits on my ~650 CHP engine.
I chose the standard RF...although I have yet to install!
#13 | |
![]() Drives: BLUE CAMARO ZL1 1LE M6 Join Date: Jun 2009
The MAF only takes a sample out of the entire area, so each time you move the MAF to a larger pipe you will have to add fuel via the MAF calibration to compensate for the lower percentage of sample. We don't move to a big gulp until 800+ RWHP Ted.
www.jannettyracing.com
Celebrating 39 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705 email tedj@jannettyracing.com |
#14 | |
The big gulp will net you nothing at this power level. I am sure there is more to be had in the tuning Your combo should easily make 600-625 RWHP on 93 octane Ted.
