Old 05-05-2021, 12:18 PM   #1
Nick.CK
Drives: 2021 Camaro 2SS 1LE (Summit White)
Two Underbody Pieces Fell Off My Brand New Camaro.
I brought this car home from the dealership not even three weeks ago.
Two days ago my friend is looking at my car from behind and notices a piece dangling near the rear left tire. I go to check it out and sure enough, 3 of the four clips that were holding this thing in were gone and the last one was cracked, so I just popped it off. The clips that Chevy uses to hold these in are clearly complete and utter garbage. This piece was missing from the other side, so lord knows where that one fell off.
It appears to be a cover for what I believe is the sway bar, maybe to prevent sand and salt from eroding it over time. I circled where these pieces go in a full underside picture below.
My question is, should I rush to get these replaced? Should I avoid driving without these plastic covers? Has this happened to anyone else or am I just the lucky winner?
Nick.CK is offline   Reply With Quote
Old 05-05-2021, 12:24 PM   #2
LT4Greg
LT4Greg's Avatar
Drives: 2017 Camaro ZL1 Coupe
Take it back to the dealer and let them reinstall them! That’s what your new car warranty is for and yes they should be on the car.
Old 05-05-2021, 12:36 PM   #3
sengli
sengli's Avatar
Drives: 2015commemorative vert 2SS
Those are just aero covers for the rear trailing suspension arms mainly for track use on ss, and ZL1 models. I never put mine on on the last several cars, cause there was no need for me anyway. These are dealer installed, as they come in a bag in the trunk on delivery to the dealer.
I would be more worried what the dealer will do if they improperly lift your car to re-install these!
2018 ZL1 Bright Yellow, A10, PDR, sunroof, carbon hood, and dash- sold
2020 2SS A10 sunroof..shock and steel special-traded
2015 commemorative vert 2ss
sengli is offline   Reply With Quote
Old 05-05-2021, 12:39 PM   #4
Rayvan
Rayvan
Drives: 2018 1SS1LE, Silver Ice Metallic
Likely damaged by the shipper/transporter. If they were "complete and utter garbage" as you say, this wouldn't be the first time any of us have ever seen this. These cars have had these since 2016.
Rayvan is offline   Reply With Quote
Old 05-05-2021, 01:35 PM   #5
dpevans
Drives: 2024 Riverside Blue 2SS 1LE
They are on all Camaros that I know of. Mine has them I think they are more for protection from salt and road grime. Not really that big a deal they probably damaged during transport.
dpevans is offline   Reply With Quote
Old 05-05-2021, 01:55 PM   #6
Doc Oc
Drives: 2017 Camaro 2SS
Yeah mine had a couple missing clips as well. They seemed useless so I took them off when doing the sways.
2017 2SS A8 TSP LT's, ported msd/95 mm, e85
Doc Oc is offline   Reply With Quote
Old 05-05-2021, 01:59 PM   #7
Number 3
Hail to the King baby!
Number 3's Avatar
Part looks like it was damaged. Impact or gouge on the one corner. Rock damage? Did you hit something?
Old 05-05-2021, 03:30 PM   #8
Spaceme1117
Spaceme1117's Avatar
Drives: 2017 Camaro SS, 2011 Corvette GS
It’s for aero. I would just order new ones for left and right and get new clips. Install them yourself. Sure it’s under warranty but do you want to give any dealership the change to screw something up on your car?
Spaceme1117 is offline   Reply With Quote
Old 05-05-2021, 03:59 PM   #9
Nick.CK
That's actually from it rubbing against my tire when it was dangling off hanging by a thread.
Old 05-05-2021, 10:33 PM   #10
zaimer
zaimer's Avatar
Drives: 23 ZL1 6speed
Welcome, welcome to the land of GM and its glorious build quality LOL. Wait until your bumpers start flexing out or your rocker panels sag.
Kidding aside! I would tell the dealer that I would like replacement parts and that I can install them myself. Have them (Chevy) pay for the parts, and you supply the labor. I don’t think I would risk a “service” visit for something so minor, particularly on that new of a car.
zaimer is offline   Reply With Quote
Old 05-06-2021, 03:15 AM   #11
R3ctivision
1LE Convert
R3ctivision's Avatar
Drives: 2018 ZLE
The replacement clips for these are like $1. I'd get new clips and pop it back on. Forget the dealer.
2016 Porsche 911 GTS (Racing Yellow)
2002 BMW Spec E46 race car (Lizard Green)
Previous cars:
- 2018 Camaro ZL1 1LE (Red Hot)
- 2018 Miata RF GT (Machine Gray/Auburn)
- 2017 Camaro 1SS 1LE (Summit White)
- 2008 BMW 135i (Montego Blue)
- 1996 BMW 328i (Arctic Silver)
R3ctivision is offline   Reply With Quote
Old 05-06-2021, 03:34 AM   #12
len_eng
Drives: 2024 Radiant Red 2SS, 1994 Z28,
When I picked up my car the covers and clips were in the trunk. My car was a dealer swap. I was told that they normally install them as part of the dealer delivery prep. Since another dealer had received the car they just assumed that they had installed the items. Damaged clips are due to bad dealer prep.
len_eng is offline   Reply With Quote
Old 05-08-2021, 03:20 PM   #13
50MileSmile
Drives: 2023 2SS, 2018 1SS 1LE, 1993 Z/28
Finally, a post in this thread that's accurate! The whole story is that GM calls this piece a Suspension Control Arm Cover (Part No. 22823593 - see #14 below from GM Parts Direct). It protects the lower rear suspension on each side from road grime, water and anything else that can hit the suspension and help it corrode. They definitely need to be in place; they arrive at the dealer in the trunk and are supposed to be installed by the dealer during PDI. My dealer didn't install them (or the rear spoiler ends either), and the prep on my '18 SS 1LE was so awful that I just picked up the car and prepped and installed everything myself - and the next day changed my warranty records to another dealer.
https://www.camaro6.com/forums/attac...1&d=1620501454
50MileSmile is offline   Reply With Quote
Old 05-08-2021, 06:55 PM   #14
Blade21
Drives: '16 Camaro 2SS
Mine were in the truck when I picked up the car also. I did not put them on...
'16 Camaro 2SS| GT-30 Cam| Kooks 1 7/8 Headers| Borla X-Pipe Mid| Mishimoto Thermostat| Mishimoto Overflow tank| Mishimoto Oil Catch Can| Diode Side Markers| ZL1 Addons Lift Pads| GM Aluminum Pedals| ROTOFAB Intake - Sound Delete| SEMA grille
Blade21 is offline   Reply With Quote
2021, camaro, help me, sway bar
