Drives: Chevrolet Join Date: Apr 2021
LT1 vs. Lt4
Whats the difference between the LT1 and LT4 other than the addition of the Super Charger?
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2019 ZL-1 Join Date: Feb 2009
LT4 has forged pistons, lower compression, and HD oil pump.
2012 Yukon XL Denali w/ 6.2 AWD |
Thank you Al Oppenheiser!
LT4 has upgraded:
Forged crank Forged pistons Powder metallurgy rods Cam (lobed for blower) LP Fuel pump HP fuel pump Injectors |
OK...so whats the difference in the LT2?
![]() ![]() ![]() Drives: 2016 Camaro 2SS Join Date: Apr 2018
The Lt1 and Lt4 share the same oil pump. Both are manufactured by melling but they're assembled at different plants. Here is a link OP about some of the differences between the Lt2 vs Lt1. https://www.google.com/amp/s/gmautho...m-the-lt1/amp/
https://www.onallcylinders.com/2018/...am-specs-more/
https://www.onallcylinders.com/2018/...le%20%28E85%29. Here are the Technical Specs for both. |
#7 |
![]() Drives: '21 Camao SS, BMW 435i, M Roadster Join Date: Oct 2020
2021 Camaro SS Riverside Blue Metallic
2014 435i M-Sport, Mineral Gray, Black Dakota Leather, Driver Asst Pkg, Prem Pkg, Tech Pkg, 8 Spd Sport AT, Heated Front Seats, ACC, BMW M Perf Tune w/MPE, BMW LSD, BBS CH. 2002 M Roadster, Steel Gray Metailic, Gray Nappa Leather, Steel Gray Metailic HT, TC Kline DA Shocks & Camber Plates, w/H&R Springs, Stromung Exhaust, SSR Type C. |
#8 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 Camaro ZL1 Coupe Join Date: May 2016
650 hp as compared to 455 in the LT1!
#9 | |
#10 |
OK...ok...so How is fuel fed to the LT2? I see no Injector ports!https://gmauthority.com/blog/2019/11...-from-the-lt1/ Last edited by Monroe; 05-01-2021 at 02:18 PM. Reason: k |
#11 |
It's direct injection just like the Lt1 and Lt4. The only gm motor that has a dual setup is the Lt5 in the Zr1. The injectors are going to be underneath the intake manifold with a high pressure fuel pump feeding them from the head.
#12 |
![]() Drives: 2023 SS 1LE Join Date: Mar 2020
LT1 wet sump crate engine: $8471.40
LT4 wet sump crate engine: $14,817.76 Or: $6346.36 in ‘extras’ |
#13 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: like an old lady Join Date: Jun 2012
taking ownership of an LT4 equipped vehicle immediately boosts your credit score and home value. that's what i was told anyway.
i felt the beginnings of a mullet when i bought my ss 1LE. so i went with it.
#14 | |
![]() ![]() ![]() Drives: 2021 Camaro ZL1 A10 Join Date: Nov 2018
2021 Camaro ZL1 A10
2022 GR Supra 3.0 Past: 2018 Mustang GT Premium w/ PP1, MR, and A10 2007 MazdaSpeed3 1995 Pontiac Trans Am 1987 Camaro Z28 |
