![]() Drives: ‘18 ZL1 / ‘22 ZLE Join Date: Oct 2013
ZL1 1LE Wheels Installed on a ZL1
There were several threads on this topic and quite a few of them didn’t have a definitive answer. Just had a set of OEM ZLE wheels installed the other day. No spacers. Stock alignment. The fitment is great! I didn’t drive the car yet but I’m sure it will be fine. Hope this helps!
#2 | |
![]() ![]() ![]() ![]() ![]() Drives: 2019 ZL1 Join Date: Mar 2019
Unless that’s not your car ?
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90 |
Yeah, that's my car. It's a regular ZL1. Based on what I've read, some people (including myself) were not sure if the ZLE wheels would fit on a ZL1 without spacers, etc. Just thought I would make a post with a definitive answer.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2021 Red Hot ZL1 Join Date: Sep 2020
Yes, they will fit.
So you added the 1le spoiler, canards , and painted/wrapped hood?
![]() Drives: 370z, Srt-6 Join Date: Aug 2017
Aren’t they the same fenders on both?
#7 | |
Fenders are the same. The shocks on the ZL1 have a section that sticks out and is very close to the wheel, which is why some people will buy spacers. Anything other than stock alignment will cause rubbing. The ZLE shocks were designed to allow clearance between the wheel and shock. |
#8 |
![]() Drives: 2010 Camaro SS 2011 Mustang GT Join Date: Apr 2011
Wheels will fit at stock alignment. At track specs the regular zl1 have to add camber at the bottom and they will rub. Zle camber is added at the top with plates
Sent from my SM-N960U using Tapatalk |
#9 | |
Nice, thats why i questioned it. I couldnt tell if it was a factory 1Le
#10 |
![]() Drives: 2020 ZL1 Camaro Join Date: Apr 2021
Why put a ZLE wing on a ZL1? That wing is hideous.
#11 |
![]() ![]() ![]() ![]() Drives: 2018 Hyper Blue ZL1 1LE Join Date: Dec 2018
He might want the benefits of the front and rear 1LE aero for the track use both the 1LE and non-1LE ZL1s were designed for. This aero package is tremendous and enables wicked lap times. I assume you don’t track your ZL1, is that right?
#12 |
![]() ![]() Drives: 2020 SS 1LE Join Date: Aug 2020
My thoughts the same. I think a ZL1 with 1le updates but keeping the MRC makes for a great setup street and track.
#13 |
It’s not for everyone, but I wasn’t crazy about the factory spoiler that came with the car. IMO the ZLE aero transforms this car and I’m sure many members on here would agree. To each their own
The mag ride is a great piece of technology. The ZLE aero and mag ride is a solid combo for sure. I personally think the ZLE looks more aggressive and better than the ZL1 |
#14 |
