Old 04-27-2021, 10:35 AM   #1
ImmDanny
Drives: 2021 1SS, 1969 Convertible
Does this panel gap seem a little big to you?
Please see pictures below. It seems like this panel gap is a little too big. Not sure if it's fixable, I've tried pushing it back up but it doesn't stay. Do you think if I remove the few bolts that hold the rear bumper in at the wheel well, peel this side of the bumper off and clip it back on would fix it?
For reference this is the driver side where the rear bumper meets the rear quarter panel just underneath the tail light. The passenger side of this area looks much tighter. It's not a huge deal, maybe it's within their tolerance from the factory.
2021 1SS Coupe 6MT
1969 Convertible Muncie 4-Speed
ImmDanny is offline   Reply With Quote
Old 04-27-2021, 10:47 AM   #2
RoninSS
Drives: 2019 SS1LE Garnet Red../Silver CL30
That panel gap expands and contracts with the ambient temperature. I notice it here in AZ.
RoninSS is offline   Reply With Quote
Old 04-27-2021, 10:48 AM   #3
ImmDanny
Well I'm also in Phoenix so I guess that would make sense then.
2021 1SS Coupe 6MT
Old 04-27-2021, 11:39 AM   #4
Travis959
Drives: 2019 Camaro 1LE
If it bothers you, you can fix it pretty easily with some zip ties:
https://www.camaro6.com/forums/showp...40&postcount=9
Travis959 is offline   Reply With Quote
Old 04-27-2021, 12:27 PM   #5
ImmDanny
Thank you that is super helpful! Although the only thing is I believe on the 16-18 camaros you could remove the tail light without removing the bumper. I think on 19+ you have to remove the tail light before the bumper. So I'm not sure this method would work, but I may be able to do something similar.
2021 1SS Coupe 6MT
Old 04-27-2021, 12:29 PM   #6
Yup, either that, or if you feel even more adventurous and willing to pop the rear bumper, perform GM TSB 17-NA-336 on the car.
Old 04-27-2021, 01:27 PM   #7
ZL1 affair
ZL1 affair's Avatar
Drives: 1of 66 Orange Crush 2020 ZL1’s
That doesn't apply to the OP car as his is a 21 and everything after 18 should have had the fix applied...
OP, take it in and have the dealer fix it...
Dreaming of a 2020 A10Crush ZL1 *TPW Sept 30* Built November 14, 2019, shipped Nov 15, 2019. Arrived at the dealer January 29, 2020.
2013 CTSV coupe 6MT SOLD
ZL1 affair is offline   Reply With Quote
Old 04-27-2021, 01:34 PM   #8
ember1205
Hot Camaro
ember1205's Avatar
The gap, and its associated expansion and contraction with heat, is "by design." The reasoning behind it is that, under conditions when the gap expands, there also exists the possibility of panels contacting each other and causing scuffing, scraping, and/or chipping of the paint.
You can take the car back to the dealership and ask the Body Shop Manager to inspect and validate whether it is within spec or not. If it is not, they can address whatever may be the issue.
Old 04-27-2021, 01:42 PM   #9
ImmDanny
After reading the ZL1 thread on this it does seem to be a thing that happens. I'd rather leave it then have the dealer mess with it. I don't trust the dealers at all unless it's something mechanical that needs to be fixed via warranty. Otherwise I'd rather them not touch the car and somehow make it worse.
2021 1SS Coupe 6MT
Old 04-27-2021, 01:56 PM   #10
LT1ornothing
Drives: 2020 LT1 M6
Would it be possible to take measurements of the gap width at the hottest part of the day and coolest part of the night to verify this expansion? Or at least compare pics of the area in question during those two exterior temperature extremes?
I understand you guys get some pretty extreme temperature swings out there in the desert, that may make the issue manifest with more frequency.
Old 04-27-2021, 02:10 PM   #11
ImmDanny
I need to test this, I only really notice it when I get home after work (hottest part of the day). I haven't checked in the morning when it's cold.
2021 1SS Coupe 6MT
Old 04-27-2021, 02:11 PM   #12
ember1205
Hot Camaro
ember1205's Avatar
Yeah, it's a slippery slope.
If you have a dealership with a body shop, you could at least go have a conversation with them. They may find a TSB on something, determine it's out of spec, etc. You could ask them to inspect only, and not disassemble or loosen anything without talking to you first (or ask if you could be present during the inspection). It all depends on the dealership and the individuals as to how much they'll try to accommodate / help for something like this.
Old 04-27-2021, 02:15 PM   #13
ember1205
Hot Camaro
ember1205's Avatar
Define cold...
Old 04-27-2021, 02:23 PM   #14
pauly1119
pauly1119's Avatar
Drives: 2018 ZLE
Looks like a Chevy body line to me. Not known for there paint and body alignment.
pauly1119 is offline   Reply With Quote
