04-26-2021, 11:30 AM | #1 |
Drives: 2010 Turbo LS3 Join Date: Dec 2009
Do you need bias fronts with bias slicks
I'm looking to move to bias ply slicks and when I was asking some technical questions, the guy on the phone said that I need bias ply skinnies on the front or it will be squirrely. I'm wanting some confirmation from drag guys on if this is true or is the guy just trying to sell more tires (which I am fine with, we all have to make money).
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. ZL1 brakes. |
06-25-2021, 03:20 PM | #2 |
Drives: T Join Date: Mar 2015
Radial up front, Bias ply in the rear is a recipe for danger. Around town you will be fine, its when you ripping at 100+ and the road has imperfections and the two different rubber compounds act drastically different. It will get ****in nuts.
Let me draw a scenario. You are on the freeway and you floor it, the nature of a bias ply tire is that it will wiggle when you wack it with power but it will correct itself, this is the nature of how the softer bis play works its just alot more soft and will correct itself, kinda like tapping something jello. When the rear tire does this and the front tire does not , it grips, it will send you into the wall when the bias ply's correct from the violent hit and the front tires just grip its bad ordeal. The fronts need to be a bias ply to match the reaction of the power being felt by the car. Bias ply tires need to be used with Bias ply tires up front. I hope this makes sense, google it and you will see it all over the place wrecked street cars with street tires up front and bias ply in the rear. a lot of people do not know the meaning or differences behind bias ply and radials. Everything under a camaro is SLICKS lolol Last edited by bayarea408; 06-25-2021 at 03:59 PM. |
06-27-2021, 03:07 PM | #3 |
Drives: 2010 SS L99 Join Date: Sep 2018
Yeah you don't want a radial on the front if you are bias in the rear. You can get away with a radial rear and a bias front. I just go bias on all 4 corners, they are slightly lighter than a radial due to their different construction, haven't had any issues. MT ET Street R bias ply 28x10/17 rear, M&H 28x4.5/17 skinny fronts, never have had any issues, GL
Previous PB:11.079 @ 122.99mph.. New setup time: TBD
The 11.079 pass: https://youtu.be/pz27Zq54t_E Build thread - www.camaro5.com/forums/showthread.php?t=555371 |
07-01-2021, 10:15 AM | #4 |
Evil Genius of Chevrolet
Drives: 2017 Z06, 2019 XTS, 2013 SS Join Date: Feb 2017
I got 2 brand new bias ply M/T's for sale if anyone interested. BRAND NEW, NO MILEAGE ON THEM. PM me.
GPI SS2 VVT cam, ECS Novi 1500 supercharger, Corsa Extreme, Detroit Speed and BMR suspension, Circle D triple disc, Melling oil pump, LS2 chain tensioner, ATI 10% UD, DSX E85 kit, High Energy coils, BTR springs, LS2 Lifter trays, Titanium retainers, hardened push rods, FIC 1000 injectors, ZL1 pump, Mighty Mouse catch can, AEM gauges, Tial BOV, Richmond 3.91 gears, Custom gauge bezels, Speed Engineering headers, Stainless Works HF cats, DSX Aux pump, 710rwhp on E85.
10-29-2021, 03:05 PM | #5 |
Writer
Drives: 2010 SS / 1967 Camaro Join Date: May 2009
I've run radials up front and bias in back and vice versa. No issues.
But if you run stock 20's up front and bias slicks in back, might not be happy... but if you have skinnies it's fine.
PROJECT HEAVY CHEVY
Camaro Now: Mods for the Masses Part I | Part II 13.15@106 1.95 | 100% Stock 12.37@112 1.85 | + Kooks Headers/Cats + 20" 555R + CAI + BW TB + UDP + Tune 12.06@113 1.70 | + CD 3200 + 18" NT05R + RCR Intake + NE OTR + GPI Tune 11.84@115 1.59 | + 3.91s + Race Star 17x7 Fronts 10.90@125 1.47 | + GPI VVT Cam + BW Ported Heads + CD 3800 |
11-28-2021, 12:07 PM | #6 |
Wow, did not realize anyone actually responded to this. Thanks for the info.
To be clear, this was not for the street, just for the drag strip. I run road course tires on the street.
11-29-2021, 11:15 AM | #7 |
Writer
I've always run auto transmissions, so when I've mixed radial fronts and slicks in back please take that into account.
They also sell bias DOT fronts too so if its stickly a track combo, that's an option. And bias tires are always lighter.
PROJECT HEAVY CHEVY
04-30-2022, 05:08 PM | #8 |
Drives: 2014 ZL1 - M6 Join Date: Jun 2014
This is exactly what i have been told by lots of guys , as long as the radials up front are skinnies.
06-09-2023, 11:44 AM | #9 | |
Served USN - Atomic Chimp
Drives: 2021 Camaro ZL1 1LE A10 Join Date: Jul 2012
So, does all this sound realistic (and seen from experience of ya)? I know next time heading to the strip, make sure I have the bias skinnies up front and us more tire pressure.
In excess of 1,000WHP LSX434 | AGP 65/65 TT | BTR Equalizer Intake | Trickflow 245cc cathedral | BTR custom cam | Cortex EBC | n2mb WOT | ID-1700x | Brisk GR12S | RPM Lv 7 TR6060 | AGP's Triple 525LPH Fore Fuel | Monster LT1-S Triple | 4.11 DSS Proform 9", CF driveshaft, 1400hp axles | Hurst Line Lock | MGW Retro Short Throw w/old skool Hurst T-handle | ADM solid subframe mounts | Prothane Motor Mounts | Revshift Poly Trans insert | Moreno camber/caster plates |
06-14-2023, 10:11 AM | #10 |
LOL!
