Old 04-26-2021, 10:03 AM   #1
shoe5163
Drives: 2017 50th Anniversary SS
Tire size
I am looking to order the 19" MRR m716 and I want the same circumference as the stock tires. So I was wondering what tire size to order and will they fit. I am looking at for the front 265/40 or 275/40 and 305/35 for the rear. These are 19s and I want more sidewall then the stock tires. I do have MRC.
Wheels front 19"x10 +23 rear 19"x11 +38
Thanks----
shoe5163 is offline   Reply With Quote
Old 04-26-2021, 10:23 AM   #2
Doc Oc
Drives: 2017 Camaro 2SS
Funny, I just did the same thing w/m755's. Saved a lot of weight. Using a tire calculator I came up with 305/35 in back and 275/40 up front as the closest to oe. Fills the wheelwell the way you want and rides better. Plus saving 7-8 lbs per corner unsprung is big. You can feel the difference. I am lowered though so not sure how the wheel gaps will look at normal ride height.
2017 2SS A8 TSP LT's, ported msd/95 mm, e85
Doc Oc is offline   Reply With Quote
Old 04-26-2021, 10:33 AM   #3
BrandanK
Drives: 2021 Camaro SS 1LE
Any photos Doc?
Brandan
BrandanK is offline   Reply With Quote
Old 04-26-2021, 11:08 AM   #4
Heat Magnet
Drives: 2021 Chevrolet Camaro 2SS
The tire sizes you mentioned are a perfect fit since the 1LE package goes up to 275 up front and 305 in the rear without sticking out. Also, the sidewalls are about the same as well.
Cars I own/drive:
  1. 2007 Chevrolet Cobalt LT Sedan
    Ultra Silver Metallic, gold painted wheel covers, 4T45 transmission
  2. 2021 Chevrolet Camaro 2SS Coupe
    Black, Redline Edition, 1LE Suspension Package, 10L80 transmission, NPP, Body color high wing spoiler, Ground effects kit, 48-state legal Brembo brakes
Heat Magnet is offline   Reply With Quote
Old 04-26-2021, 11:48 AM   #5
DaveC113
DaveC113's Avatar
Drives: 2018 Camaro 1SS 1LE
I did the same but went with 325/30/19 and 305/30/19 Michelin PS4S on Apex SM10s.
Front may need spacers but prolly not much, rear will need harness moved but that should be it.
You can also get Michelin PSS in 305/35/19 and 295/35/19, these are closest to stock.
Old 04-26-2021, 12:48 PM   #6
Mike Aruba
Mike Aruba's Avatar
Drives: 2016 2SS
My buddy is running 285/35 and 305/35. Looks very close to stock, I like it a lot.
Mike Aruba is offline   Reply With Quote
Old 04-26-2021, 01:18 PM   #7
Doc Oc
Originally Posted by BrandanK View Post
Any photos Doc?
Brandan
This is the only one on my phone but l can take some more this evening if you want?
Old 04-27-2021, 09:05 AM   #8
shoe5163
Doc oc
Are you wheel sizes the same? Do you have MRC? No fitment or rubbing issues?
Old 04-27-2021, 05:55 PM   #9
Doc Oc
Yes but I'm not positive the offsets are the same. I'll see what I can find out. No fitment issues and no rubbing yet. I haven't truly put it through the paces since the rim swap though so keep that in mind. Won't know for sure for a couple more weeks.
No MRC.
Old 04-27-2021, 11:56 PM   #10
Doc Oc
https://www.elementwheels.com/wheels...kmrr7551911blk
These are the set I got but they don't list specific offsets. Sorry.
Old 04-28-2021, 12:16 AM   #11
CamaroSSStlfan
How do you cope with the window louvers with already so so visibility on our Camaro's?
CamaroSSStlfan is offline   Reply With Quote
Old 04-28-2021, 06:13 AM   #12
shoe5163
Doc Oc
Yous wheels front 19"x10 +23 rear 19"x11 +43, so fronts identical your rears sit in .2 inches closer to frame.
Old 04-28-2021, 09:03 AM   #13
Doc Oc
Originally Posted by shoe5163 View Post
Doc Oc
Nice thanks!
Old 04-28-2021, 09:06 AM   #14
Doc Oc
It's not nearly as bad as it seems, plus I'm 6'4 so the way my seat is adjusted those windows were almost useless before hand. The louvers chop up what little view there is but don't really cause any issues in my case.
