04-24-2021, 09:41 PM | #1 |
Drives: '86 IROC-Z '18 ZL1 Join Date: Jul 2019
lt4 s/c, "best" reservoir tank?
I'm slowly doing little things to my zl1 and since I'm in AZ, I usually do cooling "mods" before going down the HP path. Anywho, for those that have added a reservoir tank to your car, which did the best job? *I know, very subjective * I'm not looking to make some crazy 1k+ hp nor do I want to add a tank in the trunk.
Right now I'm liking the Cordes tank and the ADM. personally I like the OEM look of the ADM but prefer the capacity of the Cordes and if i had to pick, id go Cordes. Any other brands that have a good 1 gal capacity without having to take off a fender or place in the trunk? |
04-24-2021, 10:20 PM | #2 |
Drives: 2017 Silverado/2017 ZL1 Join Date: Aug 2019
There's one that fits in the drivers side fender. I don't remember which one that is
04-24-2021, 10:21 PM | #3 |
I really think it depends on your use case. For a street car or road course extra capacity wont really help in the long run as it will only delay the inevitable. One way or another the temps will get to the same value, just depends how long it will get there. Now on a drag oriented car a bigger tank or trunk tank to put ice in will definitely help lower the blower IAT's or keep them low for the run. I'd choose ADM for a street car or road course, in a strip car the larger options maybe the way to go.
Morimoto Headlights, AWE Touring Catback, MM Catch Can, ADM V2 Reservoir, Roto-Fab, C&R Oil Cooler, 1LE Grills
04-25-2021, 06:38 AM | #4 |
The Cordes and ADM are only good for burping the coolant.I had the Cordes and it's definitely less than 1 gallon capacity. Only a trunk tank will help with keeping temps down the longest but eventually the inevitable will happen.
04-25-2021, 07:28 AM | #5 |
RedLine
2018 GMC 2500 "Blue" (Sold)
2018 ZL1 1LE Hyper Blue" (Sold) 2018 CTS-V "Black" (Sold) 2022 GMC 2500 "Blue" 2022 ZL1 1LE 6spd "Rapid Blue" 2023 ZL1 1LE Auto Rapid Blue (ordered) |
04-25-2021, 08:01 AM | #6 |
Drives: 2021 Red Hot ZL1 Join Date: Sep 2020
The ADM v2 looks best in my opinion, the Cordes tank has a little more volume. I've never seen the Synergy Motorsport tank before but it looks to hold the most coolant, however I'm not sure based on the pics if you would lose the benefit of being able to purge the air out of the coolant loop like you can with the ADM and Cordes tanks.
04-25-2021, 08:09 AM | #7 |
RedLine
The synergy tank has an air purge/fill hose at the top of it. It's also nicely hidden inside the fender.
04-25-2021, 11:41 AM | #8 | |
'20 ZL1 1LE A10.
LME 390, E2650, FBO, 100 oct. 1116/967. 1.35/9.25/151 at 3500 ft. (only one pass) 15" conversion/MT ET Street R 325/50R15. |
04-25-2021, 11:54 AM | #9 |
Drives: '17 ZL1 M6 Join Date: Apr 2021
ADM V2
Just did Kong ported blower, 103TB and Weapon X triple heat exchangers Bleed procedure was a walk in the park |
04-25-2021, 11:56 AM | #10 |
There are different kinds so where every they attach to. I just don't want a tank or fender version. From the sounds of it though, the ADM may be the better choice.
04-25-2021, 11:58 AM | #11 |
04-25-2021, 12:03 PM | #12 |
04-25-2021, 02:30 PM | #13 |
I saw that but not sure if it's as effective as having an auction tank mounted higher for purging.
04-26-2021, 07:08 AM | #14 |
@zle_blackwing
Drives: 2018 ZL1 1LE Join Date: Mar 2017
Cordes requires you to permanently remove the rain guard.
