![]() Drives: Chevy Camaro SS Join Date: Jan 2021
P0420 code after exhaust install
So I just installed the Stainless Works catback on my ‘16 SS and within a few weeks, the CEL came on. Code P0420. I’ve checked and there are no leaks, everything is torqued properly. I cleared the code and within a week the CEL came back on. I’m well aware that this system removed my secondary cats but I haven’t heard of anyone having CEL’s after removing the secondary cats. I was under the impression the secondary cats were not monitored. Any thoughts on this? I’m guessing I’ll need to weld the cats back on since the code is stored which will raise flags come smog time (California resident).
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '16 Garnet Red 1SS Join Date: Mar 2014
Shoot, I still have my secondary cats and still got the code.
'16 Camaro 1SS
'18 Miata GT Gone: '01 Camaro, '14 Camaro, '90 Miata |
#3 | |
![]() Drives: 2021 Camaro LT1 Conv Join Date: Oct 2016
#4 | |
Moderator
![]() ![]() Drives: 2017 Camaro SS, 2011 Corvette GS Join Date: Feb 2019
As far as I can tell, the rear O2 sensors would only be monitoring the front cats not the secondaries.
So the only way you would be getting a P0420 is if there is a leak at the connection to the front cats. Even if things are properly torqued, it can still not seal perfectly. I would get some Permatex 81878 Ultra Copper Maximum Temperature RTV Silicone Gasket Maker and apply it to the connections. |
#6 | |
Moderator
#7 | |
#8 |
![]() Drives: 2017 1LE Join Date: Nov 2017
Went through this myself some several months ago. When I put the 60606 on, followed instructions (right...) that had me remove the braded copper like gasket on driver's side. I'd presume your code did ID the left bank? So, learned that is what causes this code/left bank. Got a new primary cat assembly installed (the code prompts for replacement of the primary cat....) and of course it comes with that braided coper like gasket. About 3,500 miles or so, no issues and just passed smog / OBDII read here in GA the other day as a requirement for plates. For which they taxed me AGAIN for plates, three vehicles, I'll not get off topic...
And FWIW and best I can tell or recall the code is virtually 100% bank 1, driver's side.
'17 Bright Yellow 1LE. PDR, STB, !CAGS
Borla 60606, 11925. Tony Mamo ported TB, ROTOFAB, !Sound Tube Last edited by Chris C 1SS 1LE; 04-25-2021 at 01:54 AM. Reason: Minor Grammatical Flair II |
#9 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2021 LT1 10 speed auto Join Date: May 2013
Exhaust leak on the drivers side cat connection is the most usual spot. The right side is a flange with a metal shim gasket, that side should be OK if a new shim gasket was used. On the left side I have had luck with a exhaust wrap type sealer around the pipe and then slide the 2.5 inch clamp on and tighten
