Old 04-22-2021, 07:27 PM   #1
BruceWayne1LE
BruceWayne1LE's Avatar
Drives: 2018 Camaro SS 1LE M6
Spark Plugs Again
FBO car. LTR6IX-11 or LTR5IX-11. Tuner is telling me to run the LTR6 but sounds like stock is the LTR5??
Camaro 2SS 1LE, MBRP Catback, Mishimoto Catch Can, Rotofab dry, TSP1 7/8” headers,DSX FF, Pray ported MSD, 95mm TB
492WHP 473WTQ
BruceWayne1LE is offline   Reply With Quote
Old 04-22-2021, 08:34 PM   #2
s346k
s346k's Avatar
Drives: like an old lady
i run 5s in my bolt on car.
Old 04-22-2021, 09:25 PM   #3
BruceWayne1LE
Ted Jeanetty told me to run the 6’s. He’s not tuning it but I guess I would trust his word. Just seems weird.
492WHP 473WTQ
Old 04-23-2021, 12:20 PM   #4
6spdhyperblue
Drives: 2SS 1LE
You running 91?
Won’t you just have to replace them more often with the colder plug?
Old 04-23-2021, 01:00 PM   #5
BruceWayne1LE
Gonna run E-85 when I can. That’s where I’m confused though. I keep getting told to run the LTR6 but the stock replacement is the LTR5. I’m sure there is a reason my I’m being pushed toward the LTR6 but I have yet to get a thorough answer.
492WHP 473WTQ
Old 04-23-2021, 02:00 PM   #6
Spaceme1117
Spaceme1117's Avatar
Drives: 2017 Camaro SS, 2011 Corvette GS
A cooler plug will be less prone to detonation but will foul sooner than a stock plug.
But its likely the difference between changing the plugs at 100k versus at 50k miles.
Spaceme1117 is offline   Reply With Quote
Old 04-23-2021, 04:57 PM   #7
Doc Oc
Drives: 2017 Camaro 2SS
I'm sure he told you that because he's bumped up the timing. Log it and see. If you get any knock, change the plugs, if not stick with oe heat range.
2017 2SS A8 TSP LT's, ported msd/95 mm, e85
Doc Oc is offline   Reply With Quote
Old 04-23-2021, 05:28 PM   #8
6spdhyperblue
Drives: 2SS 1LE
I think it adds a layer of protection, I just don’t know how it would effect the E.
Old 04-23-2021, 06:07 PM   #9
s346k
s346k's Avatar
i think you're making it more complicated than it needs to be. ive been using the 5s for the last 10k miles with bolt ons and ethanol. 0 issues on gas or e85. i drive the car everywhere in the summer.
Old 04-23-2021, 10:44 PM   #10
BruceWayne1LE
I was more so just curious about why if so many are running the stock ac delco plugs with full bolt ons why sole are suggesting a step colder. Not so just curious as to a scientific reason. This tuner has a pretty solid rep out here so I’m sure he has good reason.
492WHP 473WTQ
Old 04-25-2021, 12:29 AM   #11
17camaroSS
17camaroSS's Avatar
Drives: Chevy Camaro SS
I ran factory AC Delco plugs with my bolt on, E85 setup. Car ran great with no issues and I even drove it through the winter on E as well.
2017 1SS:Hi-Ram, FBO, OTR ram air,
Circle D converter.
Previous PB: 11.07 @124 1/4
7.1 @100 1/8 1.6 60’ w/2” longtubes,
95mm hi-ram,
OTR ramair, flex fuel
17camaroSS is offline   Reply With Quote
Old 04-25-2021, 07:39 AM   #12
D3adch1ld
Drives: 2019 Camaro ZL1 1LE
Nothing weird about going on step colder with these bolt ons. Its pretty standard practice. The more you modify the colder the plug will be. In time you may also have to run tighter gaps if you are making enough power.
Sent from my SM-N986U1 using Tapatalk
D3adch1ld is offline   Reply With Quote
Old 04-25-2021, 07:46 AM   #13
6spdhyperblue
Drives: 2SS 1LE
What plugs do the zl1s run stock.
I’m stil running stock plugs as well. Has anyone noticed the car taking more timing with the colder plug?
Old 04-25-2021, 08:19 AM   #14
D3adch1ld
The LT4 uses 6 range (one step colder than ss), with my round of bolt on stuff, I did NGK LTR7IX-11, the first thing I was told to change by Vengeance before tunning... something I did notice is that these cars pull timing even in factory form unless running a boost additive. The new plugs just compensated for the additional heat in the cylinder, without them, I probably would be pulling even more timing. Should be noted, they also come pregapped about the same as factory specs which is what really matters to prevent fouling, they get plenty of heat the stay clean and a nice large gap to burn as much fuel as possible without any blowout what so ever.
If you want to run more timing, E50 did the trick for me.... I have a very happy fuel system 2900 psi at the rail, 80psi low side, inj around 5.4ms, and 23° of timing at wot every single time.
